How to Configure User Remediation for Device Control
This article explains how to configure user remediation for Device Control in Netwrix Endpoint Protector (EPP). Remediation can be set globally, at the group level, or at the computer/user level. You can also select specific devices for which remediation should be active.
Instructions
Enable User Remediation Globally
  1. In the Netwrix Endpoint Protector console, navigate to System Parameters > User Remediation, and set Enable User Remediation for Device Control to On.
Configure User Remediation Settings (Optional)
  1. On the User Remediation page, you can:
    • Add a custom logo and URL.
    • Require end users to use their credentials for remediation.
    • Modify the default and maximum time interval for remediation requests.
  2. Under Justification List, review, add, edit, delete, disable, or enable justifications for remediation.
Set Device-Specific Rights and Notifications
  1. Go to Device Control > Rights.
    • To set global rights, select Global Rights.
    • To set rights for a specific group, computer, or user, select the appropriate target.
      Set User Remediation to On for the desired devices.
  2. Go to Device Control > Settings.
    • To configure global settings, select Global Settings.
    • To configure settings for a specific group, computer, or user, select the appropriate target.
      Enable the User Remediation Pop-up.
  3. Optional: Enable the Enforce User Remediation Pop-up setting. When this is enabled, end users cannot disable User Remediation Pop-up notifications.
NOTE: If the User Remediation Pop-up is set to OFF, end users can still self-remediate from the client UI using the dedicated button.
