Set Rights for a Specific Device
Question
Is it possible to set rights for a specific device?
Answer
Yes, this is possible. Follow the steps below to set or remove rights for a specific device.
  1. In the Netwrix Endpoint Protector console, navigate to Device Control > Devices.
  2. Filter for the device to manage, then click Actions and select Manage rights.
  3. Click Add.
  4. Select the entity for which to allow the device (User, Computer, or Group).
  5. Select the desired right for the device.
  6. Click Next.
  7. From the list of users/computers/groups, select the entity to assign the new right.
  8. Select the checkboxes on the left side of the entity and click Save.
  9. To verify that the correct right is set, navigate to Device Control > Devices.
  10. Filter for the device, then click Actions and select Manage rights again.
Remove Device Rights for a Specific Computer, User, or Group
  3. From the list of entities where the device was given a specific right, click the Actions button and remove the entities where the specific right is no longer needed.
  4. To check if the right was removed, navigate to Device Control > Devices.
  5. Filter for the device, then click Actions and select Manage rights.
  • How to Add Specific Devices to the Allow List: /docs/kb/endpointprotector/[update]-_how_to_add_specific_devices_to_allow_list!
