OTP Device Code Compatibility
This article outlines recent improvements to the Offline Temporary Password (OTP) feature and the implementation of 8-digit device codes, which facilitate multiple device usage per company.
Availability
The 8-digit device code feature is available with Endpoint Protector agents version 5.7.2.4 for Windows and 2.5.1.3 for macOS.
Behavior Based on Endpoint Protector Agent Version
For Versions 5.7.2.4 (Windows) or 2.5.1.3 (macOS) and Newer:
- The user interface displays an 8-digit device code.
- OTP codes are generated based on the 8-digit device code.
For Versions Older Than 5.7.2.4 (Windows) or 2.5.1.3 (macOS):
- The user interface displays a 4-digit device code.
- OTP codes are generated based on the 4-digit device code.
Compatibility
- Codes generated from the user interface can be used with older versions.
- The Endpoint Protector Server re-computes the OTP device codes and displays them in the appropriate format according to the agent version.
