SIEM Integration Not Receiving Events
Symptom
A configured SIEM integration on the Netwrix Endpoint Protector (EPP) Server stops receiving events. In rare cases, this happens after a server migration. It can also occur independently of any migration.
Cause
After a server migration, the SIEM integration may require reconfiguration after restore.
Separately, syslog-ng is a standard Ubuntu OS daemon that runs apart from the EPP Server application. Like any OS-level service, it can stop running because of a daemon crash, service corruption, or an operating system patch or update that affects daemon startup. There is no single confirmed root cause.
Resolution
To restore SIEM event delivery, check the SIEM settings and the syslog-ng service, and restart the service if needed.
Verify the SIEM integration settings under Appliance > SIEM Integration, and reconfigure the destination if needed. See SIEM Integration for the full configuration reference.
If the settings are correct but events still do not arrive, verify that the underlying
syslog-ngservice is running on the server.NOTE: The following commands require backend (SSH) access to the EPP Server. If you do not have backend access, contact Netwrix Support and request that they perform this check on your behalf.
dpkg -l | grep syslog-ngsyslog-ng --versionsystemctl status syslog-ng -
If
syslog-ngis not running, restart the service and confirm SIEM event delivery resumes. -
If the service stays down, or events still do not arrive after a restart, contact Netwrix Support.
NOTE: If events arrive but in a different structure than before, check the server version. On version 2608, the SIEM message structure can differ from the previous format because of database changes. Version 2611 restores the previous format. See Configuring a SIEM Integration.
