Enable Encryption Option Missing from the SIEM Integration Configuration
Overview​
This article explains why the Enable Encryption option may be missing from the SIEM Integration configuration. This option allows you to encrypt communication with SIEM servers using the TCP protocol. To enable encryption, you must upload the root CA (in .pem format) that was used to sign the SIEM server certificate.
Instructions​
If the Enable Encryption option is missing, determine your appliance's operating system version:
  • Ubuntu 14.04 or older: The appliance does not support SIEM encryption. You must install an appliance with a newer OS version.
  • Ubuntu 18.04 or 22.04: The syslog-ng service may not be installed. Contact Netwrix Technical Support to verify and install the required service on the server.
