calculate percentages in SQL properly
Summary
When working with TSQL percentages you see unexpected results where a percent will either be 0 or 100.
Issue
Number values tend to be INTEGER (int) type; when working with percentages SQL expects decimal. You can fix this by explicitly converting values to a decimal type or using decimal literals. The examples below show two options.
Instructions
In the following example, both data types are int, so the result of the operation is also an int instead of a decimal, which would be required to show the percentage value you are trying to generate. For example, the following calculation returns 0:
SELECT 3/4 * 100
GO
You actually expect the answer to be 75. But SQL Server sees you dividing the integer 3 by the integer 4.
The examples below show how to get the expected result:
SELECT 3.0/4.0 * 100
GO
or
SELECT cast(3 as decimal)/ cast(4 as decimal) * 100
GO
These examples return the value you're looking for because you explicitly cast the integer values as decimals. The first example forces the integer to become a decimal by referencing the integer 3 as the decimal number 3.0. The second example uses the CAST() function to do the same.
Optionally, you can also produce a result with decimal precision. For example, to see 75.1% you can use the ROUND() function, which rounds a number to a specified number of decimal places.
Parameter: ROUND(number, decimals, operation)
Example:
SELECT cast(Round(((3*100.0)/4)) as decimal(5,1))
Legacy Article ID
2300
