How to Capture Client Logs Manually on a Linux Machine
Overview​
This article provides step-by-step instructions on how to enable and capture client logs on a Linux machine.
Instructions​
Capture Regular Client Logs​
  1. Open a terminal on the client machine and run the following commands:
    cd /var/log/epp-client/
    sudo touch /var/log/epp-client/epp_client_daemon.log
    sudo touch /var/log/epp-client/eppsslsplit.log
    sudo service epp-client-daemon restart
  2. Replicate the issue.
  3. Copy the log files to your desktop by executing the following commands:
    cp /var/log/epp-client/epp_client_daemon.log /home/user/Desktop/
    cp /var/log/epp-client/eppsslsplit.log /home/user/Desktop/
  4. Submit the log files to the support team.
NOTE: Restarting the system clears existing log entries. To retain log entries after a system restart, capture logs in append mode.
Capture Client Logs in Append Mode​
    sudo touch /var/log/epp-client/epp_client_daemon_append.log
  2. Replicate the issue or wait for the issue to occur.
  3. Copy the log files to your desktop by executing the commands:
    cp /var/log/epp-client/epp_client_daemon_append.log /home/user/Desktop/
