Netwrix Auditor Health Log Error Event ID: 6103 Suggests Contacting Netwrix Technical Support
Symptom​
You receive the following error message while collecting snapshot files:
Source:File Storage Audit Service
Event ID:6103
Computer:XXXX.XXX.local
User:N/A
Description:Monitoring plan: XXXX.
Item: XXX.XX.X.XXX.
An error has occurred during the data processing: Snapshot saving process was interrupted. Some snapshot files failed to be updated and are non-consistent. Data collection will be performed as initial.
Windows-based computers: XXX.XX.X.XXX
File shares:\\XXX.XX.X.XXX\XXXScan$
Contact Netwrix technical support at <a href="https://www.netwrix.com/support.html" target="_blank">www.netwrix.com/support.html</a>.
Cause​
An antivirus or EDR/XDR solution in your environment affects the operation of your Netwrix Auditor instance.
Resolution​
Add antivirus exclusions to both your Netwrix Auditor monitoring plan and to targets by referring to the following article: Antivirus Exclusions for Netwrix Auditor.
