Failed to grant "Log on as a service" right
During product installation you are asked to specify credentials to run the software.
But you receive the "Failed to grant the "Log on as a service" right to the service account" error.
User-added image
Password Manager is based on a service.
The service should run under an account with appropriate rights to perform required operations.
However the service account also should be allowed to run services. The right is called "Log on as a service" and can be granted via Local security policy.
Resolution
To grant the "Log on as a service" rights please:
  1. Run secpol.msc
  2. In the left pane navigate to Security Settings - Local policies - User rights assignment
  3. Double-click the Log on as a service entry in the right pane and add the account you want the service to run under
  4. Click OK to apply
User-added image
