How to run a custom powershell script with elevated privileges in a playbook
Summary​
How to run a custom PowerShell script with elevated privileges in a playbook
Issue​
A custom PowerShell script that requires elevated privileges does not run, even if the credential profile has elevated privileges.
Instructions​
  1. Upgrade the customer to 2.7 SP1 HF8 or greater
  2. In the action's Credential Profile, select a profile that has elevated privileges.
  3. Put this line of code at the start of the script, and paste the rest of the former script into the code block.
Invoke-WithImpersonation -ScriptBlock { #Insert code in here }
