Test the Password Policy
You can test the policy from the policy settings right where you are in the policy settings. You can also test it from the Password Policy Enforcer configuration console dashboard, the Windows Change Password screen, or the Active Directory Users and Computers / Local Users and Groups consoles.
Configuration Console
Test policy is available in the policy settings and on the configuration console dashboard. This option shows you the most information about the policy.
Step 1 – Click Test policy.
Step 2 – Select the PPETestUser you created. The details pane displays the policy applied to the selected user.
Enter user name for the test
Step 3 – Enter a password to test.
The Password Policy Enforcer configuration console tests the password by simulating a password change, but it does not change the user's password. A green check mark indicates the password complies, a red and white x indicates the password fails. Detailed test results appear in the results pane.
mypassword fails two requirements. You can hover over the requirements to view the associated rule.
mypassword fails
Click View log to expand Password Policy Enforcer's internal event log. The information in the event log can help you to understand why Password Policy Enforcer accepted or rejected a password.
NOTE: Policy testing simulates a password change, but it may not always reflect what happens when a user changes their password. See the Policy Testing vs. Password Changes topic for additional information.
Windows Change Password Screen
This is how most users change their password. Testing password policies from the Windows Change Password screen is useful because it allows you to see what your users see.
From the Windows Change Password screen:
Step 1 – Press CTRL + ALT + DEL.
Step 2 – Click the Change a password option.
Step 3 – Enter a user name in the User name text box.
Step 4 – Enter passwords in the Old Password, New Password, and Confirm Password text boxes.
Step 5 – Click the submit arrow.
You may have noticed that the Change Password screen looks different after installing Password Policy Enforcer. The Password Policy Enforcer password policy is shown during password changes if the Password Policy Client is installed. This helps users to choose a compliant password. The Password Policy Client also changes the message that users see when their password is rejected. Both these messages are customizable.
introduction_3
The Password Policy Client does not modify any Windows system files, and you do not have to install it to enforce a Password Policy Enforcer password policy. Web browser based versions of the Password Policy Enforcer Client are also available. See the Administration and Password Policy Enforcer Web topics for more information. Password Reset and Password Policy Enforcer/Web are licensed separately.
Active Directory Users / Computers Console and local Users and Groups Console
Administrators often change domain passwords from the Active Directory Users and Computers console and local passwords from the Local Users and Groups console. In fact, these consoles do not change passwords; they reset them. This is an important distinction because a password reset is:
  • Restricted to privileged users
  • Performed without knowing the current password
Password Policy Enforcer can enforce the password policy for both password changes and password resets. It does this by default, but you can configure it to only enforce the password policy for password changes. The Minimum Age rule is never enforced when a password is reset.
Follow the steps below to test password policies from these consoles.
Step 1 – Open the appropriate console:
  • If Password Policy Enforcer is enforcing a domain policy, open the Active Directory Users and Computers console
  • If Password Policy Enforcer is enforcing a local policy, open the Local Users and Groups console
Step 2 – Right-click a user, then click Reset Password.
Step 3 – Enter a password in the New password and Confirm password text boxes.
Step 4 – Click OK.
NOTE: These consoles do not explain why a password was rejected. Use the Password Policy Enforcer configuration console, or the Change Password screen with the Password Policy Enforcer Client installed to see this information.
Here are some sample passwords and expected test results when the Users policy is enforced. Try to change the password for the PPETestUser account to confirm that Password Policy Enforcer is enforcing the password policy correctly.
PasswordResultReason
AbdF6RejectedDoes not contain at least 7 characters
abd65fgoRejectedDoes not contain an upper alpha character
ABD65FGORejectedDoes not contain a lower alpha character
PPETest1RejectedSimilar to user logon name
AardvarkRejectedSimilar to common password (dictionary file)
tseTEPPAcceptedN/A
kravdraAAcceptedN/A
Aardv@rkAcceptedN/A
Password Policy Enforcer accepts the last three passwords in the table because they comply with the password policy, but this highlights some weaknesses in this policy:
  • tseTEPP is part of the user logon name with the characters reversed
  • kravdraA is Aardvark with the characters reversed
  • Aardv@rk is Aardvark with an @ substituting an "a."
These three passwords are only marginally stronger than the rejected passwords. The next section shows you how to improve the password policy so Password Policy Enforcer rejects these passwords.
NOTE: Contact Netwrix support if Password Policy Enforcer is not working as expected. We can help you resolve the problem.
