Using Password Reset
Netwrix Password Policy Enforcer is a web application. Users can access it from a web browser, or from the Password Reset Client. The default URL for the Web Interface is: http://[server]/pwreset/ See the Password Reset Client topic to install and configure the client application.
You can use URL parameters to open a specific page, and to set the user and domain names. For example: http://[server]/pwreset/apr.dll? cmd=enroll&username=johnsmith&domain=CORP
Where [server] is the name or IP address of the server hosting the Web Interface.
using_npr
Users access the Enroll, Reset, Unlock, and Change features from the menu. These features are explained on the following pages.
The connection between the Web Interface and Password Reset Server is always encrypted. Install an SSL certificate on the web server and use HTTPS to encrypt connections from the browser to the web server. See the Installing and Using an SSL Certificate for steps to install and configure an SSL certificate.
Enroll​
Only enrolled users can reset their password and unlock their account. Users can enroll manually by answering some questions about themselves, or they can be enrolled automatically if automatic enrollment is enabled. Users only need to enroll once, but they can enroll again if they are locked out of Password Reset, or if they want to change their questions or answers. See the Verification Codes and Verification Tab topics to configure verification code settings and automatic enrollment.
Follow the steps below to manually enroll into Password Reset.
Step 1 – Click the Enroll item in the menu.
using_npr_0
Step 2 – Type a Username, Domain, and Password.
Step 3 – Type an e-mail address if the E-mail text box is visible. See the Options topic to configure whether an e-mail address is required for enrollment.
Step 4 – Select a question from each of the Question dropdown lists, and type an answer to each question in the Answer text boxes.
Step 5 – Click Next, and then click OK to return to the menu.
Windows increments the bad password count in Active Directory when a user tries to enroll with an incorrect password. This may trigger a lockout if the Windows account lockout policy is enabled.
Reset​
Users should use the Reset feature if they have forgotten their password. Resetting a password also unlocks the account if it is locked.
Follow the steps below to reset an account password.
Step 1 – Click the Reset item in the menu.
using_npr_1
Step 2 – Type a Username and Domain, and then click Next.
using_npr_2
Step 3 – Type the Answer to the first question, and then click Next. Repeat until all questions are answered correctly.
using_npr_3
Step 4 – Password Reset may ask you to enter a verification code. The verification code is sent to your phone by e-mail or SMS. Type the Code, and then click Next.
using_npr_5
Step 5 – Type the new Password into both text boxes, and then click Next.
using_npr_6
Step 6 – Click OK to return to the menu.
Unlock​
Users should use the Unlock feature if they know their password, but have entered it incorrectly too many times and locked out their account.
Follow the steps below to unlock an account.
Step 1 – Click the Unlock item in the menu.
using_npr_7
using_npr_4
using_npr_8
using_npr_9
Step 5 – Click OK to return to the menu.
The Unlock feature unlocks accounts in Active Directory. Users who are locked out of Password Reset should re-enroll to gain access to Password Reset. See Verification Codes for details on automatic enrollment and lockout behavior.
Change​
Users should use the Change feature if they know their password and would like to change it.
Follow the steps below to change an account password.
Step 1 – Click the Change item in the menu.
using_npr_10
using_npr_11
Step 3 – Type the Old Password, New Password, and Confirm Password, and then click Next.
Step 4 – Click OK to return to the menu.
Windows increments the bad password count in Active Directory when a user tries to change their password with an incorrect password. This may trigger a lockout if the Windows account lockout policy is enabled.
Error Messages​
Validation errors appear in a red box below the page instructions. Validation errors are normally caused by invalid user input. You can often resolve them by changing the value of one or more input fields and resubmitting the form.
using_npr_12
Critical errors appear on their own page. These errors are mostly a result of configuration or system errors. Password Reset may write an event to the Windows Application event log on the Password Reset Server computer when a critical error occurs. Users can sometimes overcome a critical error by following the instructions in the error message, but most critical errors are beyond the user's control.
using_npr_13
Validation and critical error messages are stored in the HTML templates. You can modify the default messages by editing the templates. See Resource Strings for details on editing validation and error message text.
