Password Reset
What is a Password Reset?
The safest passwords are those that no one knows. A Password Reset enables passwords to be reset to a new and unknown value according to freely definable triggers. A trigger could be a definable time interval or a certain action by the user. The value of the password is changed in both Netwrix Password Secure and also on the target system.
This process will be explained below using a specific example. The password for the MSSQL user has expired. The Password Reset changes the password in Netwrix Password Secure and also in the target system to a new value.
NOTE: If an error occurs during the execution of a password reset, the affected reset is blocked with all associated passwords. This is noted in the logbook with an entry "blocked".
Due to the complexity of the process, it is strongly recommended that Password Reset is configured in combination with certified partners. The desired simplification of work processes using the above-mentioned automated functions is accompanied by numerous risks.
