Documents
The following functions are currently available in the Document module:
  • New
    New document can be added in the following ways:
    ◦ Right click -> search
    ◦ Search via the navigation bar
    ◦ By Drag & Drop (by dragging the document into the window)
  • Open properties
  • Update document
  • Notifications
  • Move
  • Favourite
  • Quick view
  • Export
  • Authorizations
  • Create external link
  • Print
  • History
NOTE: The Web Application module Documents is based on the client module of the same name “Documents”. Both modules differ in scope and design, but the operation is almost identical.
