Logbook
The logbook module exists of the following features:
  • Filter function
  • Quick view
NOTE: The Web Application module logbook is based on the same called client module logbook. Both modules differ in range and design. However, the handling is almost the same.
Differences to the logbook on the Client:
The following options are not available yet in the Web Application. If needed, you can use them on the Client.
  • Documents
  • Multifactor authentication
  • Report configuration
  • Applications
  • Password Reset
  • Password rules
  • Sytem Task
