Microsoft Edge
Installing the add-on
The installation of the Edge Add-on is done directly from the official Store. The Edge Add-on can be downloaded from the following link: Add-on for Edge.
NOTE: It is also possible to find the Add-on link in the Web Application page footer, if it is not installed yet
