Installation Web Application
This guide focuses on the initial installation of the Web Application and isn't relevant for further updates.
Preparations for installation​
System requirements​
Ensured that all Webserverr requirements have been met.
SSL certificate​
When the web service is started, the certificate created in the basic configuration is configured and connected to port 11016. This is the connection certificate for communication between the web server and the Netwrix Password Secure server.
Databases​
All databases that are to be used on the Web Application must be enabled for this purpose. With a double click the corresponding database the option "Access via Web Application" can be activated.
Installation​
The Web Application is generated by the Server Manager and made available in a ZIP archive. Depending on the web server, the ZIP archive is created accordingly. The installation also differs depending on the web server used. Irrespective of the web server used, the following information firstly needs to be entered:
Destination​
Name the folder where the ZIP archive with the Web Application should be placed.
If t Don't use the Server Manager installation directory
If the web server is created on IIS, execute config.bat to handle integration of the web server.
Server IP​
Check if the IP address is correct otherwise no connection to the Web Application can be established. If the IP address is wrong, you have to change it in the basic configuration of the Server Manager.
Web server host address​
Enter the IP address or the host name of the web server.
Port​
Enter the port that is used to communicate with the Web Application.
All of the subsequent steps or the required tasks will be explained in the associated chapters for each specific web server.
CORS configuration​
A button for the so-called CORS configuration can be found on the ribbon. It is essential that this configuration is performed before the Web Application can be used. A list of the permitted CORS domains will be saved as a result. Requests received via the Web Application can then be checked against this list. The request will only be successfully performed if the origin header for a request is available in the permitted domains.
To add a domain, enter it at the bottom of the dialogue. Clicking on :material-plus-circle-outline: will add the entry to the list at the top.
cors-en-new
In general, it is sufficient to add the IP address which was also saved as the Web server host address.
Opening the Web Application​
The process for opening the Web Application is dependent on the configuration of the web server:
  • Web Application in root directory -> https://hostname
  • Web Application in a subdirectory -> https://hostname/path-to-subdirectory
  • Port isn't set to 443 -> https://hostname:port/path-to-subdirectory
In order for the redirect to be used, ensure on apache and nginx web servers that no other host listens to port 80.
