Application
The following functions are currently available in the Application module:
Web & SAML applications:
  • Create
  • Manage
  • Delete
NOTE: A detailed explanation of how to configure SAML can be found in the chapter “Configuration of SAML”
General functions:
  • Notifications
  • Duplicate
  • Move
  • Favorite
  • Quick view
  • Connect password
NOTE: The Web Application module Applications is based on the client module of the same name “Applications”. Both modules differ in scope and design, but the operation is almost identical.
Documents
The following functions are currently available in the Document module:
  • New
    New document can be added in the following ways:
    ◦ Right click -> search
    ◦ Search via the navigation bar
    ◦ By Drag & Drop (by dragging the document into the window)
  • Open properties
  • Update document
  • Notifications
  • Move
  • Favourite
  • Quick view
  • Export
  • Authorizations
  • Create external link
  • Print
  • History
NOTE: The Web Application module Documents is based on the client module of the same name “Documents”. Both modules differ in scope and design, but the operation is almost identical.
Forms module
The following functions are currently available in the forms module:
  • Add
  • Open
  • Delete
  • Notifications
  • Duplicate
  • Favourite
  • Quick view
  • Permissions
  • Print
  • Export
NOTE: The Web Application module forms is based on the client module of the same name. Both modules have a different scope and design but are almost identical to use.
Functional scope
The Web Application will act as the basis for a constant enhancement. The current functional scope will be explained at this point. For the purposes of clarity, the relevant modules will be described in their own subsections.
General functions
  • Global settings and User settings
  • Global User rights
Functions in the individual modules
Logbook
The logbook module exists of the following features:
  • Filter function
  • Quick view
NOTE: The Web Application module logbook is based on the same called client module logbook. Both modules differ in range and design. However, the handling is almost the same.
Differences to the logbook on the Client:
The following options are not available yet in the Web Application. If needed, you can use them on the Client.
  • Documents
  • Multifactor authentication
  • Report configuration
  • Applications
  • Password Reset
  • Password rules
  • Sytem Task
Notifications
  • The permission module exists of the following features:
  • Filter function
  • Seal function
  • Mark message as read/unread
  • Quick view (use button and space bar)
The Web Application module permissions is based on the same called client module notifications. Both modules differ in range and design. However, the handling is almost the same.
Organisational structure module
The following functions are currently available in the organisational structure module:
  • Adding/editing/deleting/authorizing users / organisational structures
  • Notifications
  • Drag & Drop
  • Filter
  • Quick view
  • User settings
  • User rights
  • Changing passwords
  • Print
NOTE: The Web Application module organisational structure is based on the client module of the same name. Both modules have a different scope and design but are almost identical to use.
AD connection in the Web Application
The Active Directory connection in the Web Application works similiar to the Client. In the chapter Active Directory link you can find further information.
Organisational structure WebClient
The Web Application offers the following functions:
  • Import
  • Manual synchronisation
  • Manage profiles
Radius
You can reach the Radius server, if the import is in the Masterkey mode. The Radius server will be provided in the Active Directory profile and will therefore deliver the possible authentication methods in future. You will find further informations in the RADIUS authentication chapter.
installation_with_parameters_161
Predefining rights
To predefine rights in the Web Application, the procedure is the same as in the Client. Predefining rights)
Go to the module organisational structure to choose the organisation unit for which the rights shall be predefined. Then choose Predefine rights in the menu bar.
installation_with_parameters_162
Creating the first template group: A modal window will appear after clicking on the icon for adding a new template group (green arrow) in which a meaningful name for the template group should be entered.
installation_with_parameters_163
Now you can add the appropriate roles and users.
installation_with_parameters_164
You can add users and roles in different ways:
  • Add the appropriate roles and users at the toolbar under Search and add.
  • Click on the loupe to see all the users and roles.
installation_with_parameters_165
User management
How are the users managed in the Web Application?
The user management strongly depends on whether the Active Directory has been connected or not. In Master Key mode, the Active Directory remains the leading system. In all other modes, the user administration is carried out via the organisational structure module.
Creating local users
When creating new users, you must pay attention to whether it is a User (Basic View) or a Advanced User (View).
installation_with_parameters_166
Password module
The Password Module currently provides the following functions:
  • Create
  • Delete
  • Edit
  • Uncover password
  • Quick search
  • Add/edit form fields
  • Tagged
  • Duplicate
  • Move
  • Quick view (passwords automatically reveal)
  • Favorites
  • Filter
  • Structural filter
  • Authorization/edit rights
  • Form field authorizations
  • Change password undercover
  • Password generator with guidelines
  • Copy to clipboard
  • Open Internet page
  • View logbook
  • Display seal/visibility protection
  • German/English
  • Change user password, if “Change password at next login” is active
  • Show notifications
  • Keyboard navigation
    ◦ ALT+Q: Quick search
    ◦ ALT+N: New record
    ◦ ALT+S: Save in Edit/New View
    ◦ ALT+DEL: Delete selected record
    ◦ Arrow up/down in list: Change selection
    ◦ Right/left arrow in list: Page forward/backward
    ◦ Enter: Open selected record
  • Privacy screen
  • Seal
  • Print
  • History
  • Change form
  • Export
  • WebViewer Export
NOTE: The Web Application module Password module is based on the module of the same name that is located in the client. Both modules differ in scope and design, but are nevertheless almost identical in terms of operation.
Roles module
The following functions are currently available in the roles module:
  • Add
  • Delete
  • Notifications
  • Favourites
  • Quick view
  • Permissions
  • User rights
  • Print
The Web Application module roles is based on the client module of the same name. Both modules have a different scope and design but are almost identical to use.
Tag system
The tag system currently offers the following functions:
  • Add
  • Delete
  • Edit
