Admin Manual
Preparation​
Before you execute the migration, you must ensure that the following preparations have been made:
  • Installation of the latest Netwrix Password Secure-Server, Native Client and Web Client
  • Check in the Database properties if the offline access and the mobile synchronization are allowed If that should be the case, contact your users and ensure that they have to synchronize the Offline Add-on and the mobile app.
If the OfflineClient or App does have not yet synchronized items, they are lost after the migration mode is enabled.
  • Backup all certificates using the Netwrix Password Secure Server Manager
Only certificate backups made through the Server Manager are valid.
Certificates
Export certificates
  • Delete or restore all non “permanent deleted” users If you have deactivated or non “permanent deleted“ users it would make sense to delete them permanently, otherwise the migration would never finalize. Remember that every E2EE User must log in, before you can complete the migration.
  • Only have one active Netwrix Password Secure-Server In the case of multiple Netwrix Password Secure-Servers, you need to stop all Netwrix Password Secure-Server services on all servers except on one, which actually is used for the migration.
  • For each Entra ID profile you have to create a new token. This token must be stored in the corresponding Enterprise Application under the Provisioning tag.
Migration​
During the migration, the database is in read-only mode. So you can read all records from the database, but it isn't possible to add new or edit existing records.
Start migration​
Clicking on the icon “Start migration” in the databases' module to start the migration process
start migration
Select the database you want to migrate and enter the code-word.
Remember, The code word is “Start”. ensure that you have read the whole documentation. Otherwise, data loss might occur.
select database
You should see the message, that the selected databases are now in migration mode:
start migration
As written in the message, export all required certificates via the Netwrix Password Secure Server Manager. If you have multiple servers in use import the certificates via the Server Manager at the end of the migration process.
If certificates are missing the migration can't be continued.
Watch the migration process​
In the migration process you find all information about the current process, what is already migrated and what still needs to be migrated
migration progress
After each user has logged into the database and has been successfully migrated, the migration is complete.
migration finished
