Installing Platform Governance for NetSuite
To get Platform Governance for NetSuite up and running, you need to do the following:
  1. Install the bundle using the correct bundle name and the bundle ID.
  2. Set the number of rows in list segments to 1,000. This is a NetSuite best practice
  3. Assign a Strongpoint License.
  4. Run the spider. The spider scans your account in a standardized manner. A series of scheduled scripts is run to document the connections between the customizations.
Starting with Version 6.2.5, queues and priority allocation are deprecated. The bundle is now installed using processor architecture for scheduled scripts. All deployments are set to low priority.
Install the Bundle
The Bundle ID has been updated due to NetSuite changes.
  1. Log into your NetSuite account with the administrator role.
  2. Open Customization > SuiteBundler > Search & Install Bundles
  3. Enter 294336 in Keywords
  4. Click Search
    Search for the Strongpoint Bundle
  5. Click Strongpoint
  6. Click Install to start the bundle installation.
  7. Verify the installation is complete. Open Customization > SuiteBundler > Search & Install Bundles > List
    In the Installed Bundles list, the Strongpoint bundle is marked with a green check in the Status column when the bundle is installed.
    Verify Strongpoint Bundle Installation
Set the Number of Row in List Segments
It is important that you set your NUMBER OF ROWS IN LIST SEGMENTS to 1,000. This is a NetSuite best practice and critical for the proper spidering of your workflows. If you are unable to edit this field, refer to Cannot Change the Number of Rows in List Segments
To set the Number of Rows in List Segments:
  1. Select Set Preferences from Home on the NetSuite main menu.
  2. Go to Optimizing NetSuite.
  3. Set the value to 1,000.
  4. Click Save.
If the field is grayed out, it should be set as a Company Preference:
  1. Select Company Preferences from Set Up > General Preferences on the NetSuite main menu.
  2. Find the field Number of Rows in List Segments
  4. Click Save
Assign a License
  1. Open Strongpoint > Strongpoint Support > License Manager
  2. Click View.
  3. Click New Licensed User.
  4. Click Edit by your name.
  5. Select Full for License Type.
  6. Click Save.
Next Step: Running the Spider
