How to Configure a Duo RADIUS Proxy for Multi-Factor Authentication
This article lists the steps to configure a Duo RADIUS proxy server as a multi-factor authentication (MFA) provider for Netwrix Privilege Secure (NPS).
IMPORTANT: Privilege Secure only supports Duo as a secondary authentication provider. Password authentication is still handled by Netwrix Privilege Secure.
Instructions
  1. On your RADIUS server, follow the following path to open the authproxy.cfg file.
%ProgramFiles%\Duo Security Authentication Proxy\conf\authproxy.cfg
  1. Add a [duo_only_client] section heading to the file and save the file. The new heading should precede the [radius_server_auto] section heading. See the following code block for a reference:
[duo_only_client]
ikey=%value%
skey=%value%
api_host=%value%
radius_secret_1=testing123
radius_ip_1=192.168.77.20
failmode=safe
client=duo_only_client
port=1812
NOTE: Take note of values in the [radius_server_auto] section—these are used to configure NPS for Duo authentication. If you maintain multiple Duo configurations for applications, take note of values in [radius_server_auto1], [radius_server_auto2], etc.
  1. Log in to the NPS console as a user with the Administrator role. Navigate to Configuration > Authentication.
  2. Verify the following points:
  • IP, Remote Port, and Shared Secret match the corresponding values in the authproxy.cfg file.
  • The Prefix for Response Text field contains a comma. In case the PAP protocol is used, no prefix is needed.
  • Both Initial Auto-Response Text and Send Initial Text features are optional. If you specify the push auto-response text and enable the Send Initial Text feature, a Duo push is automatically initiated.
  1. Save the changes to the configuration.
NOTE: You can assign Duo as an authenticator connector for any NPS user. In the main NPS screen, click Policy > Users & Groups. Select any user and proceed to the Authenticator Connector tab. Select the Duo option.
On their login to NPS, the configured user should both enter their password and see the multi-factor authentication prompt from Duo. During the initial login, they are asked to perform the initial Duo enrollment.
