Configuring a Duo RADIUS Proxy for Multi-Factor Authentication
This article describes how to configure a Duo RADIUS proxy server as a multi-factor authentication (MFA) provider for Netwrix Privilege Secure for Access Management.
IMPORTANT: Privilege Secure only supports Duo as a secondary authentication provider. Password authentication is still handled by Privilege Secure.
Instructions
On your RADIUS server, open the
authproxy.cfgfile at the following path:%ProgramFiles%\Duo Security Authentication Proxy\conf\authproxy.cfg -
Add a
[duo_only_client]section heading to the file and save the file. The new heading should precede the[radius_server_auto]section heading. See the following code block for reference:[duo_only_client][radius_server_auto]ikey=%value%skey=%value%api_host=%value%radius_secret_1=testing123radius_ip_1=192.168.77.20failmode=safeclient=duo_only_clientport=1812NOTE: Take note of values in the
[radius_server_auto]section—these are used to configure Privilege Secure for Duo authentication. If you maintain multiple Duo configurations for applications, take note of values in[radius_server_auto1],[radius_server_auto2], etc. -
Log in to the Privilege Secure console as a user with the Administrator role. Go to Configuration > Authentication.
Verify the following points:
- IP, Remote Port, and Shared Secret match the corresponding values in the
authproxy.cfgfile. - The Prefix for Response Text field contains a comma. If the PAP protocol is used, no prefix is needed.
- Both Initial Auto-Response Text and Send Initial Text features are optional. If you specify the
pushauto-response text and enable the Send Initial Text feature, a Duo push is automatically initiated.
Save the changes to the configuration.
NOTE: You can assign Duo as an authenticator connector for any Privilege Secure user. In the main Privilege Secure screen, click Policy > Users & Groups. Select any user and proceed to the Authenticator Connector tab. Select the Duo option.
When the configured user logs in to Privilege Secure, they should both enter their password and see the multi-factor authentication prompt from Duo. During the initial login, they are asked to perform the initial Duo enrollment.
