Invalid Multi-Factor Authentication Code Error
Symptom​
  • When a user attempts to log in to the Netwrix Privilege Secure console using the multi-factor authentication code, the page refreshes. The user is prompted to provide credentials again.
  • A multi-factor authentication (MFA) code is deemed invalid. Login fails with the following error:
Invalid MFA code
Authenticator code login page showing the Invalid MFA code error
Cause​
The Netwrix Privilege Secure server and client have a system time discrepancy.
Resolution​
Review the system time on both the Privilege Secure server and clients in your environment.
NOTE: You can set the system time to sync with the OS time server automatically − in your server settings, select Time & Language > Date & Time > switch the Set time automatically switch on.
