Integrating Privilege Secure for Access Management with Auditor
This article describes how to set up the Netwrix Privilege Secure for Access Management integration in Netwrix Auditor. The article is split into sections to segment the setup process. See the corresponding section for the required steps.
Instructions
Perform the Initial Setup in Netwrix Auditor
In the main Netwrix Auditor menu, go to Settings > Privilege Secure. If this is the first time you are setting up the integration, click the Set Up Integration button.
Specify the Privilege Secure server name or the IP address with the corresponding port, and click Next. For example, with the default 6500 port:
https://contoso-nps:6500/ -
If the Privilege Secure server certificate is untrusted on the Netwrix Auditor host, select the I want Auditor to trust this certificate when connecting to this server checkbox and click Next.
Take note of the application name. You can keep the default name or change it. This article uses the default NetwrixAuditor name.
NOTE: It is not recommended to use a space in the application name, as this may lead to incorrect operation when using Microsoft Entra ID.
In the Specify the client certificate section, select Generate new certificate and click Next.
Export the Netwrix Auditor Privilege Secure for Access Management client certificate to the Privilege Secure server. See the Export the Certificate to Privilege Secure for Access Management Server section.
In the Dashboard tab of Privilege Secure, click Users > Add > New Application User.
Specify the application name to match the application name stated in Netwrix Auditor. The default name is NetwrixAuditor.
Copy the certificate serial number value from your Netwrix Auditor server. Click Save.
After you save the details, Privilege Secure generates an API key. Reveal the key, copy the value, and paste it in the API key field in the Privilege Secure Integration window of your Netwrix Auditor server.
In the Netwrix Auditor server, click Next > Finish to complete the initial setup.
- On the Netwrix Auditor server, start the Microsoft Management Console—press Windows + R, enter mmc, and click OK.
- Go to File > Add/Remove Snap-in...
- In the left pane, locate the Certificates snap-in, highlight it, and click Add >.
- In the pop-up windows, select Computer account > Next > Local computer > Finish.
- Click OK to save the snap-in.
- In the left pane, go to Certificates (Local Computer) > Personal > Certificates.
- Locate the Netwrix Auditor Privilege Secure for Access Management Client certificate, right-click it, and select All Tasks > Export...
- In the Export Wizard, click Next > No, do not export the private key > Next > DER encoded binary > Next.
- Specify the target location and name the certificate. Click Next, then click Finish.
- A message to confirm the successful export should appear. Confirm the export by reviewing the target location.
- Copy the exported certificate to the Privilege Secure server.
- On the Privilege Secure server, right-click the certificate and select Install.
- Select Local machine > Next > Place all certificates in the following store: > Trusted Root Certification Authorities > Next > Finish. A message to confirm the successful import should appear.
Create a Connection Profile
NOTE: Both credential-based and resource-based integrations require a connection profile. The steps to set up a connection profile are the same for both types of integration.
- In Privilege Secure, select the Policy tab and go to Access Policy > Connection Profiles in the left pane.
- Click the plus icon to add a new connection profile. For the generic workflow, see Connection Profiles Page.
- Name the connection profile to distinguish it from other non-integration-related connection profiles.
- Set the following required connection profile settings:
- Allow Proxy Auto-connect = True
- Record Proxy Session = True
- Session Control
- Max Duration = 60
- Session End Notification = 5
- Enable Session Extension = False
- Monitor for Logon = False
- Leave Existing Members in Group = True
- Validate Users for SSH Sessions = False
- Require Notes for Sessions = False
- Require Ticket Number for Sessions = False
- Credential Management
- Allow User to Access Password = True
- Enable credential auto-fill in browser extension = False
- Enable
Show Passwordoption in user interface and browser extension = False - View Password Timeout = 20
- Website
- Clear Website Data Before Start = True
- Clear Website Data After Stop = True
- Record Session Audio = True
- Approval Workflow = Automatic
- Click Save to save the profile settings.
Setting Up the Resource-Based Policy for Integration
The resource-based type of the integration requires the following items:
- Activity
- Resource
See the following subsections for the required steps.
Create an Activity
- In Privilege Secure, select the Policy tab and go to Activities in the left pane.
- Click the plus icon to add a new activity. For the generic workflow, see My Activities Page.
- Specify the activity name. This article uses the Netwrix Auditor Domain Admin name. Set the following required activity settings:
- Platform = Active Directory
- Login Account = Activity Token
- Activity Type = Interactive
- Login Account Template =
%targetDomain%\%samAccountName%
- Click Save to save the changes.
- Add an action to the pre-session—click the plus sign next to the Pre-Session (Grant) section.
- Set the following required pre-session action settings:
- Action Type = Add User to Domain Group
- Domain =
%target_domain% - Group = Domain Admins
- Continue on Error = False
- Action Name = Add to Domain Admins
- Paired Action's Name = Remove from Domain Admins
- Click Okay to save changes.
Create a Resource
In Privilege Secure, select the Policy tab and go to Resources in the left pane.
Click Add and select New Server. Select Import from AD and select the target domain controller.
NOTE: In environments with multiple domain controllers, select the primary domain controller.
In the bottom right corner, select the service account, and click Add.
Create a Resource-Based Access Policy
- In Privilege Secure, select the Policy tab and go to Access Policy in the left pane.
- Click the plus icon to add a new access policy. For the generic workflow, see Access Policy Page.
- Enter a policy name.
- Verify the Type value is Resource Based. Select the dedicated connection profile and click Save.
- Select the Users tab and click Add to add a user. Select the application user (NetwrixAuditor by default) and click Add.
- Select the Activities tab and click Add to add an activity. Select the Netwrix Auditor Domain Admin activity and click Add.
- Select the Resources tab and click Add to add a resource to manage. Select the target resources and click Add.
Setting Up the Credential-Based Policy for Integration
- Specify the account for Privilege Secure to control—in the Dashboard tab, select the Credentials section and locate the target domain account.
- Select the corresponding checkbox and click Manage. Click Automatic.
- In the Policy tab, select the Access Policy menu in the left pane. Click the plus icon to add a new access policy. For the generic workflow, see Access Policy Page.
- Verify the Type value is Credential Based. Select the appropriate dedicated connection profile and click Save.
- Select the Credentials tab and click Add to add the managed account. Select the managed account and click Add.
Enable Integration in Target Monitoring Plan
In the Monitoring Plans menu, select the target monitoring plan.
Double-click the target item. In the Specify the Account for Collecting Data section, select Privilege Secure.
Depending on the policy type, select the Credential-based or the Resource-based type in the Access Policy field.
For a credential-based policy, specify the user name of the user account for collecting data.
For a resource-based policy, specify the activity name and the resource name in the corresponding fields.
IMPORTANT: Specify the names as stated in Privilege Secure.
Click Save & Close.
