Registering and Using the sbpam-url SSH Protocol Handler
Overview​
This article describes how to register the sbpam-url SSH protocol handler and use it to automatically connect to an SSH session proxied by Netwrix Privilege Secure for Access Management.
The sbpam-url utility, located in the Extras folder of the download package, registers an SSH URL handler.
For additional information, see Invoking Desktop SSH Client Automatically.
At the time this article was written, the referenced KB article instructed users to download the utility from a static link, which may provide an outdated version. Use the utility bundled in the Extras folder to ensure you have the latest version.
Instructions​
Where to Install or Run the Utility​
The URL handler must be registered on the machine where Privilege Secure users run their browser. Ensure you run the utility on the appropriate client system.
Example Commands for External SSH Clients​
Use the following PowerShell commands and arguments for various external SSH clients:
# Register Putty
& .\sbpam-url handle -p ssh -- "C:\Program Files\PuTTY\putty.exe" -ssh -P '{{port}}' '{{user}}@{{hostname}}'
# Register Windows 10 (OpenSSH)
& .\sbpam-url handle -p ssh -- C:\Windows\System32\OpenSSH\ssh.exe '\{\{URL\}\}'
# Register RoyalTS
& .\sbpam-url handle -p ssh -- "C:\Program Files (x86)\Royal TS V5\RoyalTS.exe" '/username:{{user}}' /password:a /protocol:terminal /using:adhoc '/uri:ssh://{{host}}'
# Register MobaXTerm
& .\sbpam-url handle -p ssh -- "C:\Apps\MobaXterm_Professional_9.4\MobaXterm_Professional_9.4.exe" -newtab 'ssh -o PasswordAuthentication=no -l {{user_esc}} -p {{port}} {{hostname}}'
NOTE: Each time you run the handle command, it replaces the previous handler with the new one.
Remove the SSH Handler​
To remove the SSH handler, run the following command:
& .\sbpam-url handle -U -p ssh
Alternatives to sbpam-url​
You can use WinSCP to install an SSH handler as an alternative to sbpam-url.
NOTE: WinSCP requires Putty to be installed first.
Command Reference​
General Command-Line Form​
Use the following syntax to register a handler:
sbpam-url handle -p <protocol> -- <Command to run using replacement strings>
Available Commands​
CommandDescription
completionGenerate the autocompletion script for the specified shell
handleRegister a URL handler
helpDisplay help about any command
Command Flags​
FlagDescription
-h, --helpDisplay help for sbpam-url
-d, --debugDisplay debug messages
-Q, --quietDo not display messages
-u, --url stringURL to handle
-v, --versionDisplay version information
handle -p <protocol>Handle the specified protocol
handle -uUnregister all protocols
handle -u -p <protocol>Unregister a specific protocol
Available Replacement Strings​
Replacement StringDescription
{{scheme}}Protocol, for example, SSH
{{user}}User portion of the URL (direct connect string)
{{user_esc}}Escaped user portion of the URL
{{host}}The host and port in the format host:port
{{hostname}}Just the hostname
{{port}}Just the port
{{path}}The URL path
{{query}}The URL query
{{fragment}}The URL fragment
{{password}}The password portion of the URL
Registry Keys Modified by sbpam-url​
The sbpam-url utility updates the following registry keys to register the protocol handler:
[HKEY_CLASSES_ROOT\ssh]
@="URL: ssh Protocol"
"URL Protocol"=""
"EditFlags"=dword:00000002
"BrowserFlags"=dword:00000008
[HKEY_CLASSES_ROOT\ssh\DefaultIcon]
[HKEY_CLASSES_ROOT\ssh\shell]
[HKEY_CLASSES_ROOT\ssh\shell\open]
[HKEY_CLASSES_ROOT\ssh\shell\open\command]
[HKEY_CURRENT_USER\Software\Classes\SbPAM.URL]
@="SbPAM URL Handler"
"URL Protocol"=""
"DefaultIcon"=""
[HKEY_CURRENT_USER\Software\Classes\SbPAM.URL\shell]
[HKEY_CURRENT_USER\Software\Classes\SbPAM.URL\shell\open]
[HKEY_CURRENT_USER\Software\Classes\SbPAM.URL\shell\open\command]
@=""" --url "%1""
[HKEY_CURRENT_USER\Software\Classes\Applications\sbpam-url.exe]
"FriendlyAppName"="SbPAM URL Handler"
[HKEY_CURRENT_USER\Software\RegisteredApplications]
"SbPAM"="Software\Stealthbits\SbPAM\SbPAM.URL\Capabilities"
[HKEY_CURRENT_USER\Software\Stealthbits\SbPAM\SbPAM.URL\Capabilities]
"ApplicationDescription"="SbPAM handler application for URLs"
"ApplicationName"="SbPAM URL Handler"
[HKEY_CURRENT_USER\Software\Stealthbits\SbPAM\SbPAM.URL\Capabilities\UrlAssociations]
[HKEY_CURRENT_USER\Software\Stealthbits\SbPAM\SbPAM.URL\URLHandlers]
"ssh"=""
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\Associations\UrlAssociations\ssh\UserChoice]
"Progid"="SbPAM.URL"
