Resolving "Invalid Connection String" for DirectConnect in mRemoteNG
Symptom​
In a specific scenario, valid Netwrix Privilege Secure for Access Management DirectConnect strings used in mRemoteNG result in an invalid connection string error, stating the connection string is empty.
Screenshot of Netwrix Privilege Secure DirectConnect error, stating the connection string is invalid (empty).
Cause​
This error is caused by having credentials saved for the Privilege Secure server (for example, the Privilege Secure Proxy Server) in the Windows built-in Remote Desktop Protocol (RDP) client, Remote Desktop Connection, on the same host that is running mRemoteNG.
Screenshot of a credential saved in Remote Desktop Connection, the built-in Windows RDP client, for the Netwrix Privilege Secure Proxy Server.
Resolution​
To resolve the issue, choose one of the following two options:
  • Delete the credential saved in Remote Desktop Connection. After you delete that credential, the valid DirectConnect string works as expected in mRemoteNG.
  • Fill in a password for each DirectConnect connection saved in mRemoteNG. This resolves the issue without deleting any credentials from Remote Desktop Connection.
