Configuring and Upgrading in High Availability Mode and Using Remote Services Configurations
Overview​
This article describes how to configure PostgreSQL high availability (HA) for Netwrix Privilege Secure for Access Management using the NPS.HaMgr.exe (NPS HA Configuration Tool). It also includes steps to upgrade an existing HA server pair and to upgrade remote service nodes. The NPS.HaMgr.exe tool is available in the Extras folder of the Privilege Secure download directory. This implementation of HA is active/passive—if the primary server becomes unavailable, you must perform a manual failover to switch to the secondary database. All applications and services remain active on their respective servers; however, both write only to the primary database.
NOTE: If the primary server becomes unavailable and a failover is required, see the "Upgrade an Existing NPS High Availability (HA) Pair" section for steps."
IMPORTANT: Before configuring HA, perform the following steps on both primary and secondary Privilege Secure servers:
  1. Open the HA tool. Click the folder icon to the right of the PgDataDir path to open the Postgres folder.
  2. Locate the Archive folder. Delete the contents of the Archive folder.
IMPORTANT: After establishing the HA pair, use the primary Privilege Secure server. The database on the secondary server runs in read-only mode in the HA pair.
IMPORTANT: A reboot is required on all Privilege Secure servers for both initial installations and upgrades.
This article contains the following sections:
  • Initial Configuration
  1. Before You Begin
  2. HA Upgrade Instructions
    1. Failover and Upgrade the Secondary
    2. Upgrade the Primary
    3. Re-establish HA on the Secondary
    4. Verify the Secondary
    5. Verify the Primary
  3. Remote Service Upgrade Instructions
    1. Upgrade the Netwrix Privilege Secure Server
    2. Upgrade All Remote Services
    3. Export the Encryption Keys from the Netwrix Privilege Secure Server (Action and Scheduler Services only)
    4. Copy the Encryption Keys to the Remote Hosts (Action and Scheduler Services only)
    5. Re-register the Services on the Netwrix Privilege Secure Server
  4. HA Troubleshooting
Instructions​
Initial Configuration​
Complete the following steps to configure an HA pair:
  1. Verify that both 5432 (PostgreSQL) and 6500 (Privilege Secure Web Services) ports are open between the servers.
    • If either port was modified, open the corresponding port instead.
    • The HA tool creates exclusion rules for Windows Firewall, but your network firewall may still block these ports.
  2. Copy the HA tool from the Extras folder to the following folder on both primary and secondary servers:
    C:\Program Files\Stealthbits\PAM\HA Tools
    If required, replace the default installation path with a custom one.
  3. Run the HA tool on the primary server. Specify the primary server IP in the Primary IP field. Allow the tool to process the IP to then fill the Port value. A green checkmark appears in the Primary Node section.
    IMPORTANT: The Primary IP field only registers IP addresses. The field does not register FQDNs or localhost (127.0.0.1).
  4. Specify the secondary server IP in the Secondary IP field. Specify the Port value (5432 by default for PostgreSQL). After specifying the values, click any white space in the window of the HA tool to process the secondary IP and port.
    IMPORTANT: Some errors and warnings can be ignored during the initial setup:
    • The %Secondary_IP% not found in pg_hba.conf error indicates no established connection between the PostgreSQL databases. This behavior is expected.
    • The Firewall Port Not Open warning does not get updated after the HA tool creates a firewall rule.
    IMPORTANT: Do not proceed to the next step until both servers have a green check mark in the HA Manager.
  5. Follow the instructions in Configuring Encryption Keys in Multiple NPS Server Environments to export the encryption keys from the primary server to the secondary server.
  6. On the primary server, locate the appsettings.json file at C:\ProgramData\Stealthbits\PAM\HA\appsettings.json and copy it to the same path on the secondary server.
  7. Run the HA tool on the secondary server. Specify the Primary IP, Primary Port, and Secondary IP.
    IMPORTANT: The HA tool might prompt errors and warnings after you enter the values. This behavior is expected. Do not update or refresh any of the fields.
  8. Close the HA tool on both the primary and secondary servers.
  9. Run the HA tool on the primary server and verify the IP address and port fields. Click Update in the Secondary Node section to update the pg_hba.conf file.
  10. Run the HA tool on the secondary server. Allow the tool to initialize—a Configure HA Secondary button should appear in the top right corner of the tool window.
    NOTE: If the Configure HA Secondary button does not appear, close the tool on both servers, restart the primary HA tool, and start the secondary HA tool.
  11. Click the Configure HA Secondary button. Proceed with the backup for the existing database—the stream from the primary to the secondary should begin after. The initial streaming may take several minutes depending on the amount of data to be replicated.
    NOTE: To confirm HA is configured, review the Postgres Status values for both nodes—they should state Running Primary and Running Replica depending on the role.
  12. Verify that you can log in to Privilege Secure on both servers.
Before You Begin​
Determine whether your Privilege Secure environment has HA and/or remote services configured.
  • For HA, launch the Privilege Secure HA Configuration Tool (NPS.HaMgr) that was packaged with your installer on your primary server. If Replication Status is listed as Active, HA is configured.
  • For remote services, launch Privilege Secure and check whether any remote hosts are listed under service nodes. If there are, you have remote services that need to be upgraded.
If neither of these is configured, you may proceed with a standard Privilege Secure upgrade and bypass the steps outlined in this article. Otherwise, proceed to the appropriate sections for HA and/or remote services.
NOTE: When upgrading from 3.6 or higher to 3.7CU1 (3.7.1250) or higher, it is assumed that all of your encryption keys are in agreement on all Privilege Secure servers and remote service nodes. The 3.7CU1 installer retains the existing encryption keys on each server, and you can omit any steps in the following instructions involving the export and import of encryption keys.
HA Upgrade Instructions​
Each host in the active/passive configuration must be upgraded, starting with the secondary (passive) host and proceeding to the primary (active) host. After both hosts are upgraded, the primary and secondary are restored to an HA configuration and their services are re-registered in the Privilege Secure console. If the secondary can't connect or decrypt data after the upgrade, see HA Troubleshooting.
Step 1 — Failover and Upgrade the Secondary​
  1. Create a new folder in your Privilege Secure installation folder:
  2. Copy the HA Manager Tool from your download directory Extras\NPS.HaMgr.exe to the installation folder C:\Program Files\Stealthbits\PAM\HA Tools. If you have an older copy of the HA Tool, ensure you copy the existing configuration file over so the tool has the previous configuration values.
  3. Start the HA Manager Tool NPS.HaMgr.exe.
  4. Click the Failover button on the HA Tool UI. This updates the PostgreSQL database on the secondary so the upgrade can be performed on the secondary without impacting the primary.
    NOTE: Clicking Failover flips the IP Address of the primary and the secondary hosts. Ensure you undo this change after the upgrade.
  5. Run NPS_Setup and click the Upgrade Netwrix Privilege Secure button.
  6. After the installer completes, close the installer and close NPS_Setup.
Step 2 — Upgrade the Primary​
  2. Copy the HA Manager Tool from the download directory Extras\NPS.HaMgr.exe to the installation folder C:\Program Files\Stealthbits\PAM\HA Tools. If you have an older copy of the HA Tool, ensure you copy the existing configuration file over so the tool has the previous configuration values.
  4. The tool shows that HA is not configured; this is addressed later.
Step 3 — Re-establish HA on the Secondary​
  1. Launch the HA Tool on the secondary server.
  2. Enter the primary IP address into the Primary IP text box.
  3. Enter the secondary IP address into the Secondary IP text box.
  4. Click the Configure HA button.
Step 4 — Verify the Secondary​
  1. Connect to the secondary Web UI directly.
  2. Log in with a Privilege Secure Administrator account (domain\\user).
  3. Go to the Configuration > System Settings > Services page. Verify the URL is properly configured so the services are communicating with the secondary service.
  4. Click Register Services.
  5. Go to Service Nodes.
    • Verify that your secondary server shows up as online.
    • Verify that your primary server shows up as online.
Step 5 — Verify the Primary​
  1. Connect to the primary Web UI directly.
Remote Service Upgrade Instructions​
In addition to upgrading the Privilege Secure server, you must upgrade each remote host with a remote service. After remote hosts are upgraded, steps are included to ensure that the remote services share the same encryption keys as the Privilege Secure server. After the encryption keys match, the services are re-registered in the Privilege Secure console.
NOTE: The encryption key import instructions apply only to remote Action and Scheduler services—not Proxy services.
Step 1 — Upgrade the Netwrix Privilege Secure Server​
  1. Run NPS_Setup and click the Upgrade Netwrix Privilege Secure button.
  2. After the installer completes, close the installer and close NPS_Setup.
Step 2 — Upgrade All Remote Services​
  1. Run the appropriate service-specific installer on each remote host (for example, ActionService.exe for the Action Service).
  2. After the installer completes, close the installer.
Step 3 — Export the Encryption Keys from the Netwrix Privilege Secure Server (Action and Scheduler Services only)​
  1. On the Privilege Secure server, run cmd as Administrator.
  2. Enter the following commands to export the encryption keys for the secondary:
    cd "C:\Program Files\Stealthbits\PAM\KeyTools"
    .\SbPAM.RotateKey.exe export -n keys.exp
  3. Take note of the password for the export file.
    IMPORTANT: This temporary password protects the Privilege Secure encryption keys during copying. Do not save it to digital media or transmit it with the encryption key package.
Step 4 — Copy the Encryption Keys to the Remote Hosts (Action and Scheduler Services only)​
For each remote host running a remote service, do the following:
  1. Copy the keys.exp file to C:\Program Files\Stealthbits\PAM\KeyTools.
  2. Run cmd as Administrator. Enter the following commands to import the encryption keys:
    .\SbPAM.RotateKey.exe import -n keys.exp
    You are prompted for the password.
  3. Delete the export file from the remote host.
After all remote hosts have the correct encryption keys, delete the export file from the Privilege Secure server.
Step 5 — Re-register the Services on the Netwrix Privilege Secure Server​
  3. Click Register Services.
  4. Go to Service Nodes. Verify that all remote service nodes are listed as online.
HA Troubleshooting​
Complete the following steps to manually configure critical HA settings on your HA pair:
  1. On the primary server, go to the %PROGRAMDATA%\Stealthbits\Postgres16 folder. The following is the default path:
    C:\ProgramData\Stealthbits\Postgres16
  2. Open the pg_hba.conf file using a text editor. Add the following lines to the end of the file:
    host replication repuser %SECONDARY_IP%/32 md5
    host all all %SECONDARY_IP%/32 md5
    Replace the %SECONDARY_IP% placeholders with the IP address of your secondary server. Save the changes.
  3. On the secondary server, go to the %PROGRAMDATA%\Stealthbits\Postgres16 folder. The following is the default path:
  4. Open the pg_hba.conf file using a text editor. Add the following lines to the end of the file:
    host replication repuser %PRIMARY_IP%/32 md5
    host all all %PRIMARY_IP%/32 md5
    Replace the %PRIMARY_IP% placeholders with the IP address of your primary server. Save the changes.
If the secondary can't connect or decrypt after an upgrade​
Newer upgrades keep the existing appsettings.json file and encryption keys, so you normally don't need these steps. If the secondary can't connect to the primary or can't decrypt data after the upgrade, complete the following procedures on the primary and the secondary.
Copy the appsettings.json file to the secondary​
Copy the encryption keys to the secondary​
  1. On the primary server, run cmd as Administrator.
  4. Copy the export file to C:\Program Files\Stealthbits\PAM\KeyTools on the secondary server.
  5. On the secondary server, run cmd as Administrator.
  6. Enter the following commands to import the encryption keys:
  7. Delete the export file from both the primary and secondary servers.
