Onboarding Network Devices Using TACACS Access Control
Overview​
This article describes how to onboard TACACS-enabled network devices as Netwrix Privilege Secure for Access Management resources. You need to create a custom Platform for the device, and a corresponding service account. If multiple types of devices are to be onboarded, multiple sets of custom Platforms and service accounts can be used.
Instructions​
Step 1 — Creating a Platform​
  1. Go to Policy > Platforms. Select the Linux platform, and click the Copy icon.
    The Platforms page with the Linux platform selected and the Copy icon.
  2. Rename the Linux Copy platform that was just created. The name should reflect the device you intend to onboard, in this case Fortinet. Set the Password Complexity Policy to Default and all change policies to <none>.
Step 2 — Creating a Service Account​
  1. Go to Configuration > Service Accounts.
  2. Click the + icon and create a new Service Account whose name corresponds to the device you intend to onboard (again, Fortinet in this example).
    The Service Accounts page with the new Fortinet service account.
    NOTE: This service account is not used to scan the target device since it is not a supported Platform, so any username/password can be provided.
Step 3 — Onboarding the Network Devices​
  1. Create a CSV file with the following columns: DNS Host Name, Operating System, IP Address, Platform, Credential.
  2. Populate the CSV file with information for all devices that are to be onboarded.
    NOTE: Ensure that the Platform exactly matches the custom Platform you have configured in Privilege Secure. Ensure that the Credential exactly matches the service account you have configured in Privilege Secure.
    A CSV file populated with the columns DNS Host Name, Operating System, IP Address, Platform, and Credential.
  3. Go to the Resources page. Click +Add, and select New Server. On the Add Resources page, select Import from CSV, and select the CSV file you have created. Your resources should be displayed.
    NOTE: There is a 50-resource batch size limit for CSV import.
    The Add Resources page with Import from CSV selected.
  4. Click Add. The resources are added and a host scan is attempted for each one. This host scan fails, which is expected for unsupported platforms during initial onboarding.
    The Add Resources page listing the resources to add, with the Add button.
    The resources added to the Resources page, with the failed host scan results.
Your resources should now be visible on the Resources page.
Notes for Creating an Activity​
When creating an Activity that uses domain credentials, do not use the %targetdomain% variable in the Login Account Template. Use the name of the domain, as indicated.
The Login Account Template field of an Activity showing the domain name.
NOTE: Group membership add/remove operations are needed if access control groups are used for the target devices.
After the activity is configured, it can be added to an access policy in the usual manner, and used to run an activity.
An access policy that includes the activity.
Running the activity from the access policy.
