Resolving "No Common Algorithm for Key Exchange" SSH Error for Cisco Resources
This article describes how to resolve the SSH error "no common algorithm for key exchange" when Netwrix Privilege Secure for Access Management brokers an SSH connection to a Cisco resource.
IMPORTANT: This article applies only to Cisco connections.
Privilege Secure may not be configured to use the same key exchange algorithm as a target resource when brokering an SSH connection. In that case, the following error appears in the PAM-SSHClient log:
Error="ssh: handshake failed: ssh: no common algorithm for key exchange; client offered: [ARRAY_OF_ALGORITHMS], server offered: [ARRAY_OF_ALGORITHMS]"
NOTE: In this error, the two arrays of algorithms do not contain any shared algorithms.
Instructions
Complete the following steps to configure the use of the same key exchange algorithm as a target resource when brokering an SSH connection:
Choose an acceptable algorithm from the list of server offered algorithms given in the error message you have received. For example, suppose your server offered diffie-hellman-group14-sha1.
On your Netwrix Privilege Secure server, go to the ActionServiceWorker directory.
NOTE: On a default installation, it should be
C:\Program Files\Stealthbits\PAM\ActionServiceWorker -
Open the
sbpam_sshclient.jsonfile in a text editor. -
Go to the KeyExchanges section, which should resemble the following:
"KeyExchanges": ["diffie-hellman-group-exchange-sha256","diffie-hellman-group-exchange-sha1","diffie-hellman-group1-sha1" -
Modify the array to include your desired algorithm, keeping the array properly comma-separated. In this example:
"KeyExchanges": ["diffie-hellman-group-exchange-sha256","diffie-hellman-group-exchange-sha1","diffie-hellman-group1-sha1","diffie-hellman-group14-sha1"You should now be able to negotiate an SSH connection with the target resource using its preferred algorithm.
