Replay Viewer Window
The Replay Viewer window allows a user with the Administrator role to watch a recorded activity session. Activity sessions are recorded when the Record Proxy Sessions checkbox is selected in the connection profile assigned to the access policy. All SSH and RDP keystrokes and local commands are recorded using a granular metadata search that works across both live and recorded sessions.
When recordings are available for a historical session, the expand icon is enabled on the Historical Dashboard.
Multiple recording can exist for a session. There are two types of Replay Viewer windows:
- RDP session
- Website host
Select the desired recording and the Replay Viewer window opens.
Replay Viewer for RDP Sessions
The Replay Viewer window for RDP sessions is applicable to all resources except the Websites.
The Replay Viewer for RDP Sessions window has the following features:
Play options
- Control buttons — Play, pause, rewind, or fast forward the recording
- Playback bar — Click to jump to a specific place in the recording
- Speed slider — Use the slider to adjust the playback speed
Recording Details
User— Displays the account used to log onto the resource
- logged on to — Displays the name of the resource
- using — Displays the name of the resource the RDP session connected from
Activity — Displays the name of the activity
Proxy Session Started — Indicates when the activity started. This refers to when the activity’s actions were executed and not when the user was logged on to the resource.
Ended — Indicates when the activity ended.
Duration — Indicates how long the Activity ran for until it either reached its scheduled end time or was manually canceled by the user or an Privilege Secure administrator
Activity Details:
Time line — Displays recorded activity that occurred during the session in the pane to the left of the player. By default this time line will include keystroke activity.
NOTE: If RDP Session Monitoring is enabled, then it will also include Windows metadata activity in the time line. This monitoring requires the Netwrix Privilege Secure Remote Desktop Monitor service to be installed on the target host. See the Install Remote Desktop Monitor Service on Target RDP Hosts topic for additional information.
Replay Viewer for SSH Sessions
The Replay Viewer for SSH sessions is applicable to Linux and Cisco resources.
The Replay Viewer for SSH Sessions window has the following features:
Play options
Recording Details
Activity Details:
- Time line — Displays recorded activity that occurred during the session in the pane to the left of the player. By default this time line will include keystroke activity.
Replay Viewer for Website Host Sessions
The Replay Viewer window for Website host sessions is applicable only to Website hosts.
The Replay Viewer for Website Host Sessions window has the following features:
Play options
- Control buttons — Play or pause the recording
- Sound icon — If available, click to adjust sound volume
- Full Screen icon — Click to open the player in full screen or return to window size
- Playback speed — Select Playback speed from the Options menu to adjust player speed
- Picture in picture — Select Picture in picture from the Options menu to enable feature
Recording Details
- using — Displays the name of the resource the session connected from
