SSO: Duo Access Gateway (DAG)
This topic covers integrating Privilege Secure with Duo using a Duo on-premise Duo Access Gateway (DAG) SSO. Please find an article detailing the Privilege Secure terms here: SSO Configuration
Prerequisites
Duo service plan with the following:
  • Duo Access Gateway (DAG)
  • Active Directory (AD) sync configured and synced
  • Single Sign-On enabled
  • Duo Active Directory Authentication Proxy Agent Installed and configured for AD sync and SSO
  • Single Sign-On Authentication Source configured and tested
Duo:  Duo Access Gateway Configuration
Step 1 – Login to Duo Access Gateway Admin Console.
Step 2 – Navigate to the page for authentication source, and add the attribute that corresponds to the DUO user name attribute in the attributes field.
Step 3 – Select Applications in the left side bar.
Step 4 – Locate the metadata section. This is the information you need to provide to the DUO Network Gateway when configuring the DAG IDP.
Step 5 – Select the Download certificate.
Due: Create the DUO Application for Privilege Secure
Step 1 – Open a new tab and log into the Duo Admin Panel
Step 2 – In the left side bar, select Applications > Protect an application.
Step 3 – Type in SAML, select SAML Duo Network Gateway.
Step 4 – At the top of this, enter the FQDN of the new server and select save configuration.
Step 5 – At the top of the new application’s property page, click ‘Download your configuration file’ to get the file in JSON format.
Step 6 – Return to the DAG Admin Console.
Step 7 – Add application, select choose file.
Step 8 – Locate the file you just downloaded and click ‘open’, then upload.
Step 9 – Return to the Duo Admin Panel.
DAG Parameters:
NOTE: \{\{base_url\}\}= URL used to reach Privilege Secure internally.
  • Configure SAML Service Provider
    • Use -PROD and -DEV or -STG to differential environments
    • Can be selected by client, must match entry in Privilege Secure
    • Use different Entity IDs for PROD and non-PROD
    • Example: {{base_url}}-PROD
  • Service provider name: Privilege Secure-PROD
  • Entity ID:\{\{base_url\}\}
  • Assertion Consumer Service:\{\{base_url\}\}/api/login
  • Single Logout URL (Optional): <leave blank>
  • Default Relay State (Optional): <leave blank>
SAML Response:
  • NameID: urn:oasis:names:tc:SAML:2.0:attrname-format:unspecified
  • NameID attribute: <Username>
  • Send attributes: <select NameID radial>
  • Signature algorithm: <select SHA-256>
  • Sign response: <checked>
  • Sign assertion: <checked>
  • Map attributes:
  • idP Attribute:distinguishedName
  • SAML Response Attribute:dn
  • Create attributes (Optional):
  • Name: <leave blank>
  • Value: <leave blank>
Step 10 – Duo: Retrieve SAML/SSO information for Privilege Secure.
Step 11 – Privilege Secure: Enter SAML/SSO information.
Step 12 – Privilege Secure: EEnable SSO in Privilege Secure and Login Example.
Step 13 – At the bottom of the Configure > Server > SAML Configuration Panel, enable or disable SSO when appropriate:
  • Privilege Secure SSO Login Screen
  • Click the SSO Login button to log in via Duo.
Troubleshooting
If you are using ADFS as an authentication source and receive a "SAML Assertion Not Yet Valid" while trying to log in, please see:  Configure ADFS (Active Directory Federation Services) SSO
Additional Information
https://duo.com/docs/authproxy-reference
https://duo.com/docs/sso-generic
