AD Failover
AD Failover
AD Failover
Prior to 2.12, should an LDAP Sync fail (for any reason) the Privilege Secure LDAP Sync Service would not perform any retry logic, or attempt to use an alternate server.
With the LDAP Sync Directory Server Failover feature, the LDAP Sync service can be configured to attempt synchronization with other servers automatically when the server being used becomes unavailable.
This document will go over that logic, as well as the database schema needed to support it, as well as the logs that are introduced.
Feature Functionality
Standard / Shared LDAP Sync Behavior
This refers to the general behavior / flow of LDAP sync in general, regardless of DC failover or errors encountered
When LDAP Sync runs
Get the list of all
ldap_config
documents in the Privilege Secure database, each of which corresponds to a configured AD domain- Attempt to sync with every domain serially, moving onto the next domain after the domain sync has finished by completing or failing.
Wait for the configured “Run Interval Minutes”, then repeat this cycle
LDAP Sync Behavior (Failover: Disabled)
With LDAP Sync Directory Server Failover disabled, the LDAP Sync cycle occurs as described above:
- Any connection error that occurs during an LDAP sync for a particular domain will cause it to stop
- Nothing further is attempted for this DC until the next sync cycle
- The next configured domain is processed if any exist
LDAP Sync Behavior (Failover: Enabled)
With DC Failover enabled, we maintain the same general flow - attempt to sync with one domain at a time, moving onto the next one after one has finished (error or not) - however we handle failures for each domain differently.
When a connection error (SERVER_DOWN
or TIMEOUT
) is first encountered during a sync for a
domain
See if the criteria has been met for considering a DC failed or not. In 2.12, the only criteria is the number of attempts made against a particular DC
If the failure criteria has not been met, retry the current DC, waiting a (configurable) period of time in between connection attempts, until the sync succeeds or the criteria is met
The number of retry attempts per DC is configurable in the UI in the Server page, under the settings for each domain. The wait between retry attempts is 1s (this is not configurable in the UI).
If the failure criteria has been met for a single DC:
- A list of DC’s is acquired from DNS MSDCS SRV records and is sorted by the
priority
property. This is also how theDirectory Connection Settings > Detect
function in the UI chooses a domain when configuring a domain.- Right now, there’s only one strategy for sourcing -
dns_priority
- but in the future, we can support additional options like a customer-defined list. - Command to check the DNS MSDCS SRV record from any system, replace "domain.com" at end
with name of domain checking:
nslookup -type=SRV _ldap._tcp.dc._msdcs.domain.com
The next DC in the prioritized list is attempted to be used until a viable DC is found or the list is exhausted.
If the failover process results in using a different DC rather than the “initial DC”:
- All attempted syncs will be
init
syncs
CAUTION: This is not a full_sync
init_sync
will do a group flattening process, but will not move stale objects -
full_sync
will not do a group flattening process, but will move stale objects -
We have decided to do an
init_sync
as this mimics what Customer Success currently does to recover from an AD failure. This feature “automates” this approach within the product.- The manual failover process is to update the
ldap_config
with a new DC, and set the the USN values to 0. - According to ldap_sync behavior, when a sync is started with a
highest_usn
value of 0, it will switch the sync intoinit_sync
mode.
Any successful connection / ldap bind to an alternate DC will immediately update the
ldap_config
with this new DCs info-
The intent is to optimistically update the config ASAP to restore AD user authentication ASAP. A successful connection is a strong positive signal the new DC is viable.
The
previous_usn
andhighest_usn
values are set to 0- This will ensure that if an unexpected error occurs after a successful connection
connection, the next ldap sync cycle, will initiate an
init_sync
, rather than starting from USN values misaligned with the recently-set DC
CAUTION: There can still be an ldap connection error after this point, which could occur during the search for ldap entries or authentication. It’s worth noting that we get ldap data (for any type) as paged results, so every time we request a new page is an opportunity for a connection to go bad.
Any "Ldap Sync Activity" (what shows up in the UI as the "status" for the domain) will be prepended with
Failover DC Attempt:
- This will prepend all activity messages for this domain until the next ldap sync cycle
The result of the domain failover attempt (regardless of success or fail) will be saved in the database
- There is currently no ui view into this, it is primarily there to help answer questions should the need arise, and to support a UI later if needed
- This will record the initial DC, any attempted DCs, whether the failover routine succeeded or failed on the whole, and the new DC, as applicable
Database
CAUTION: There is an associated migration which must be run in order for this feature to work properly!
The DC Failover feature’s configuration lives on an ldap_config
db document in the
secureone_config
collection.
Assuming all existing ldap_config
fields are not shown, the schema will be the following:
ldapConfig = {
failover_config: {
enabled: Boolean,
failover_dc_source: 'dns_priority', // currently the only option
dc_fail_criteria: {
// There is another strategy which is based on total duration (regardless of number of attempts)
// however it is advised we do not use that now as it introduces complexity strategy: 'retry_attempts',
// This field is for the alternate strategy mentioned above, safe to ignore for now
// total_duration_seconds: Number
retry_attempts_max: Number, // Default of 5. Is configurable via the UI as of 2.12
wait_between_attempts_seconds: Number, // Default of 1. is NOT configurable via the UI as of 2.12 },
failover_history: [{
initial_dc: {
server: String,
port: Number,
attempted_dcs: [{
server: String,
port: Number,
failover_dc: { // Or null, if failover did not succeed
server: String,
port: Number,
failover_success: Boolean,
sync_start: Date, // Start of the sync process for the domain
sync_end: Date, // end of the sync process for the domain. IOW will account for the time spent attempting all DCs
Logs
In addition to the failover history being updated, we have implemented logs for this feature.
Existing logging in ldap sync should remain unchanged (additions only).
The following logs are roughly in order one might encounter them, and do not include otherwise-present log fields that are in all ldap logs.
Log Entry Trigger | Log Level | Message field | Details (key:value pairs in the log “details”) |
Starting the initial ldap sync for a DC (failover not enabled) | info | "Attemping LDAP Sync" | dc_failover_enabled: false current_dc: server, port of current dc |
Starting an LDAP sync for a DC, on any attempt after the first (failover enabled) | warning | "Domain Controller (DC) Failover: Attempting LDAP Sync" | dc_failover_enabled: t/f is_initial_dc: t/f current_dc: server, port of current dc current_dc_connection_attempts: Number of connection attempts per this DC attempted_dcs_count: Total number of attempted DCs |
After any error has occurred during ldap sync, failover disabled | error | "Error encountered during LDAP Sync" | dc_failover_enabled: t/f current_dc: server, port of current dc error: dict containing error details |
After any error has occurred during ldap sync, failover enabled | error | "Domain Controller (DC) Failover: Error encountered during LDAP Sync" | dc_failover_enabled: t/f current_dc: server, port of current dc current_dc_try_count: number of connection attempts per this dc current_dc_try_duration_sec: total eslapsed time attempting connection to this dc, in seconds error: dict containing error details |
Connection has failed, failure criteria for current dc not yet met (retry attempts) | warning | "Domain Controller (DC) Failover: LDAP Sync failed - Retrying current DC | current_dc: server, port of current dc fail_strategy: "retry_attempts" attempts_max: Max number of retry attempts before trying the next pto a different DC attempts_current: number of attempts already completed |
Connection has failed, failure criteria for current dc has been met and we are movig onto the next DC | warning | "Domain Controller (DC) Failover: LDAP Sync failed - Using next DC" | next_dc: server, port attempted_dcs: server, port of attempted (and failed) dcs remaining_additional_dcs: server, port of additional DCs to try |
Connection has failed, failure criteria for current dc not yet met, waiting to retry | info | "Domain Controller (DC) Failover: Waiting to retry current DC" | server: hostname of current dc wait_for_sec: number of seconds waiting in between retry attempts |
Initial DC has failed, failover enabled, was able to look up additional DCs via DNS | warning | "Domain Controller (DC) Failover: Found additional DCs" | additional_dcs: list of alternate DCs that will be attempted (ordered by priority), comprised of server, port additional_dc_source: source of additional dcs, currently should just be "dns_priority" |
warning | "Domain Controller (DC) Failover: Unable to find any additional DCs" | additional_dc_source: source of additional dcs, currently should just be "dns_priority" | |
Initial DC success | * No new log added, it is already logged by svc_ldap * | ||
Initial DC failed and failover DC has successfully synced | info | "Domain Controller (DC) Failover: LDAP Sync failover succeeded" | initial_dc: server, port of initial DC attempted_dcs: List of attempted (and failed) dcs, comprised of server, port failover_dc: The fail-overed dc hostname sync_start_ts: timestamp of sync start sync_end_ts: timestamp of sync end, including all faiilover attempts |
Initial DC failed and failover not enabled | error | "LDAP Sync failed" | dc_failover_enabled: false error: dict of error details sync_start_ts: start time of sync sync_end_ts: end of sync incuding all time spent in failover routine |
Initial DC failed and failover is enabled and unsuccessful | error | "Domain Controller (DC) Failover: LDAP Sync failed for all available DCs" | dc_failover_enabled: true initial_dc server: server, port of the initial dc attempted_dcs: list of attempted (and failed) dcs, comprised of server, port sync_start_ts: start time of sync sync_end_ts: end of sync incuding all time spent in failover routine |
Example Logs
{ "asctime": "2021-08-18 19:39:28,295", "levelname": "INFO", "message": "Starting LDAP Sync", "name": "svc-ldap", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:28,298", "levelname": "CRITICAL", "message": "Starting ldapsync, relaunching every 20 minutes", "name": "svc-ldap", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:28,304", "levelname": "INFO", "message": "Next full sync will occur: Thu, 19 Aug 2021 00:00:00", "name": "svc-ldap", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:28,312", "ldapName": "rtest.com", "levelname": "INFO", "message": "Syncing LDAP for rtest.com", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:28,328", "details": { "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "dc_failover_enabled": true }, "ldapName": "rtest.com", "levelname": "INFO", "message": "Attempting LDAP Sync", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:28,332", "details": { "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "current_dc_try_count": 1, "current_dc_try_duration_sec": 0.003807, "dc_failover_enabled": true, "error": { "desc": "LDAP Timeout" } }, "ldapName": "rtest.com", "levelname": "ERROR", "message": "Domain Controller (DC) Failover: Error encountered during LDAP Sync", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:28,335", "details": { "attempts_current": 1, "attempts_max": 2, "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "fail_strategy": "retry_attempts" }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: LDAP Sync failed - Retrying current DC", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:28,342", "details": { "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "wait_for_sec": 1 }, "ldapName": "rtest.com", "levelname": "INFO", "message": "Domain Controller (DC) Failover: Waiting to retry current DC", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:29,347", "details": { "attempted_dcs_count": 1, "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "current_dc_connection_attempts": 2, "dc_failover_enabled": true, "is_initial_dc": true }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: Attempting LDAP Sync", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:29,351", "details": { "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "current_dc_try_count": 2, "current_dc_try_duration_sec": 1.02252, "dc_failover_enabled": true, "error": { "desc": "LDAP Timeout" } }, "ldapName": "rtest.com", "levelname": "ERROR", "message": "Domain Controller (DC) Failover: Error encountered during LDAP Sync", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:29,362", "details": { "attempts_current": 2, "attempts_max": 2, "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "fail_strategy": "retry_attempts" }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: LDAP Sync failed - Retrying current DC", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:29,365", "details": { "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "wait_for_sec": 1 }, "ldapName": "rtest.com", "levelname": "INFO", "message": "Domain Controller (DC) Failover: Waiting to retry current DC", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,370", "details": { "attempted_dcs_count": 1, "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "current_dc_connection_attempts": 3, "dc_failover_enabled": true, "is_initial_dc": true }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: Attempting LDAP Sync", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,373", "details": { "current_dc": { "port": 389, "server": "dc1.rtest.com" }, "current_dc_try_count": 3, "current_dc_try_duration_sec": 2.044849, "dc_failover_enabled": true, "error": { "desc": "LDAP Timeout" } }, "ldapName": "rtest.com", "levelname": "ERROR", "message": "Domain Controller (DC) Failover: Error encountered during LDAP Sync", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,376", "details": { "additional_dc_source": "dns_priority", "additional_dcs": [ { "port": 389, "priority": 0, "server": "dc3.rtest.com", "weight": 100 }, { "port": 389, "priority": 4, "server": "dc2.rtest.com", "weight": 100 } ] }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: Looking up additional DCs", "name": "svc-ldap", "server": "dc1.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,379", "details": { "attempted_dcs": [ { "port": 389, "server": "dc1.rtest.com" } ], "next_dc": { "port": 389, "server": "dc3.rtest.com" }, "remaining_additional_dcs": [ { "port": 389, "priority": 4, "server": "dc2.rtest.com", "weight": 100 } ] }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: LDAP Sync failed - Using next DC", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,382", "details": { "attempted_dcs_count": 2, "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "current_dc_connection_attempts": 1, "dc_failover_enabled": true, "is_initial_dc": false }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: Attempting LDAP Sync", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,392", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; connecting to ldap://dc3.rtest.com:389", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,395", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; binding to ldap://dc3.rtest.com:389 (elapsed: 0:00:00.003421)", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,415", "exc_info": "Traceback (most recent call last):\n File \"/secureone/remediant/ldap_kit/__init__.py\", line 50, in get_bound_ldap_connection\n _type, _data, _msg_id, _ctrls = conn.simple_bind_s(bind_dn, bind_pass)\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 228, in simple_bind_s\n msgid = self.simple_bind(who,cred,serverctrls,clientctrls)\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 222, in simple_bind\n return self._ldap_call(self._l.simple_bind,who,cred,RequestControlTuples(serverctrls),RequestControlTuples(clientctrls))\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 108, in _ldap_call\n result = func(*args,**kwargs)\nSERVER_DOWN: {'info': 'Invalid argument', 'errno': 22, 'desc': \"Can't contact LDAP server\"}", "ldapName": "rtest.com", "levelname": "ERROR", "message": "{'info': 'Invalid argument', 'errno': 22, 'desc': \"Can't contact LDAP server\"}", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,426", "details": { "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "current_dc_try_count": 1, "current_dc_try_duration_sec": 0.044208, "dc_failover_enabled": true, "error": { "desc": "Can't contact LDAP server", "errno": 22, "info": "Invalid argument" } }, "ldapName": "rtest.com", "levelname": "ERROR", "message": "Domain Controller (DC) Failover: Error encountered during LDAP Sync", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,429", "details": { "attempts_current": 1, "attempts_max": 2, "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "fail_strategy": "retry_attempts" }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: LDAP Sync failed - Retrying current DC", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:30,433", "details": { "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "wait_for_sec": 1 }, "ldapName": "rtest.com", "levelname": "INFO", "message": "Domain Controller (DC) Failover: Waiting to retry current DC", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:31,439", "details": { "attempted_dcs_count": 2, "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "current_dc_connection_attempts": 2, "dc_failover_enabled": true, "is_initial_dc": false }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: Attempting LDAP Sync", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:31,444", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; connecting to ldap://dc3.rtest.com:389", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:31,447", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; binding to ldap://dc3.rtest.com:389 (elapsed: 0:00:00.003426)", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:31,458", "exc_info": "Traceback (most recent call last):\n File \"/secureone/remediant/ldap_kit/__init__.py\", line 50, in get_bound_ldap_connection\n _type, _data, _msg_id, _ctrls = conn.simple_bind_s(bind_dn, bind_pass)\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 228, in simple_bind_s\n msgid = self.simple_bind(who,cred,serverctrls,clientctrls)\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 222, in simple_bind\n return self._ldap_call(self._l.simple_bind,who,cred,RequestControlTuples(serverctrls),RequestControlTuples(clientctrls))\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 108, in _ldap_call\n result = func(*args,**kwargs)\nSERVER_DOWN: {'info': 'Invalid argument', 'errno': 22, 'desc': \"Can't contact LDAP server\"}", "ldapName": "rtest.com", "levelname": "ERROR", "message": "{'info': 'Invalid argument', 'errno': 22, 'desc': \"Can't contact LDAP server\"}", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:31,467", "details": { "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "current_dc_try_count": 2, "current_dc_try_duration_sec": 1.085234, "dc_failover_enabled": true, "error": { "desc": "Can't contact LDAP server", "errno": 22, "info": "Invalid argument" } }, "ldapName": "rtest.com", "levelname": "ERROR", "message": "Domain Controller (DC) Failover: Error encountered during LDAP Sync", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:31,470", "details": { "attempts_current": 2, "attempts_max": 2, "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "fail_strategy": "retry_attempts" }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: LDAP Sync failed - Retrying current DC", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:31,474", "details": { "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "wait_for_sec": 1 }, "ldapName": "rtest.com", "levelname": "INFO", "message": "Domain Controller (DC) Failover: Waiting to retry current DC", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,477", "details": { "attempted_dcs_count": 2, "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "current_dc_connection_attempts": 3, "dc_failover_enabled": true, "is_initial_dc": false }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: Attempting LDAP Sync", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,485", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; connecting to ldap://dc3.rtest.com:389", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,490", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; binding to ldap://dc3.rtest.com:389 (elapsed: 0:00:00.005157)", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,511", "exc_info": "Traceback (most recent call last):\n File \"/secureone/remediant/ldap_kit/__init__.py\", line 50, in get_bound_ldap_connection\n _type, _data, _msg_id, _ctrls = conn.simple_bind_s(bind_dn, bind_pass)\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 228, in simple_bind_s\n msgid = self.simple_bind(who,cred,serverctrls,clientctrls)\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 222, in simple_bind\n return self._ldap_call(self._l.simple_bind,who,cred,RequestControlTuples(serverctrls),RequestControlTuples(clientctrls))\n File \"/usr/local/lib/python2.7/site-packages/ldap/ldapobject.py\", line 108, in _ldap_call\n result = func(*args,**kwargs)\nSERVER_DOWN: {'info': 'Invalid argument', 'errno': 22, 'desc': \"Can't contact LDAP server\"}", "ldapName": "rtest.com", "levelname": "ERROR", "message": "{'info': 'Invalid argument', 'errno': 22, 'desc': \"Can't contact LDAP server\"}", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,527", "details": { "current_dc": { "port": 389, "server": "dc3.rtest.com" }, "current_dc_try_count": 3, "current_dc_try_duration_sec": 2.145052, "dc_failover_enabled": true, "error": { "desc": "Can't contact LDAP server", "errno": 22, "info": "Invalid argument" } }, "ldapName": "rtest.com", "levelname": "ERROR", "message": "Domain Controller (DC) Failover: Error encountered during LDAP Sync", "name": "svc-ldap", "server": "dc3.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,532", "details": { "attempted_dcs": [ { "port": 389, "server": "dc1.rtest.com" }, { "port": 389, "server": "dc3.rtest.com" } ], "next_dc": { "port": 389, "server": "dc2.rtest.com" }, "remaining_additional_dcs": [] }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: LDAP Sync failed - Using next DC", "name": "svc-ldap", "server": "dc2.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,540", "details": { "attempted_dcs_count": 3, "current_dc": { "port": 389, "server": "dc2.rtest.com" }, "current_dc_connection_attempts": 1, "dc_failover_enabled": true, "is_initial_dc": false }, "ldapName": "rtest.com", "levelname": "WARNING", "message": "Domain Controller (DC) Failover: Attempting LDAP Sync", "name": "svc-ldap", "server": "dc2.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,549", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; connecting to ldap://dc2.rtest.com:389", "name": "svc-ldap", "server": "dc2.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,555", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; binding to ldap://dc2.rtest.com:389 (elapsed: 0:00:00.005444)", "name": "svc-ldap", "server": "dc2.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:32,857", "ldapName": "rtest.com", "levelname": "INFO", "message": "Open connection; connection opened and bound (duration: 0:00:00.307741)", "name": "svc-ldap", "server": "dc2.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:33,000", "details": { "attempted_dcs": [ { "port": 389, "server": "dc1.rtest.com" }, { "port": 389, "server": "dc3.rtest.com" } ], "failover_dc": "dc2.rtest.com", "initial_dc": "dc1.rtest.com", "sync_end_ts": "2021-08-18T19:39:33.000228", "sync_start_ts": "2021-08-18T19:39:28.328537" }, "ldapName": "rtest.com", "levelname": "INFO", "message": "Domain Controller (DC) Failover: LDAP Sync failover succeeded", "name": "svc-ldap", "server": "dc2.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:33,016", "ldapName": "rtest.com", "levelname": "INFO", "message": "Completed LDAP Sync for rtest.com in 4.70408797264 seconds", "name": "svc-ldap", "server": "dc2.rtest.com", "threadName": "MainThread"}{ "asctime": "2021-08-18 19:39:33,043", "levelname": "INFO", "message": "Completed LDAP Sync", "name": "svc-ldap", "threadName": "MainThread"}
