Add a Domain
Add a Domain
Add a Domain
The purpose of this document is to outline the steps for an Admin to configure a domain within Privilege Secure. It will also cover the available Windows authentication methods.
Main Document
  • As an Admin navigate to Configure -> Server.
  • Click "Add Domain" which exposes the configuration details:**.
  • Type in the domain and click Detect.
  • From here you can add the 3 main accounts (Bind, Scan, and Protect). Click Test Connection once all credentials have been input.
  • Configure default policies.
Authentication Methods
NTLM is the default applicable to most organizations.
Kerberos authentication was added in version 2.13.0. The key considerations are:
  • When Kerberos authentication is selected Privilege Secure will only attempt to authenticate using Kerberos.
  • Kerberos is designed in a way that requires connecting using SPNs/fully-qualified hostnames only -- not via IP address. As a result, we need to ensure that DNS correctly reflects the online IP address of the target system on the network.
  • With Kerberos selected, the IP address override field on the Grant Access page will not function.
If you switch from NTLM to Kerberos we recommend restarting the worker and scanner service. This can be accomplished in both the UI and the terminal.
  • With Privilege Secure version 2.17 we can support SASL and Kerberos.
    • The REALM entry must be fully capitalized
      • e.g. user@REALM
    • SASL is not compatible with SSL
      • Microsoft SASL and SSL are not compatible
      • Requires port 389
  • Kerberos is DNS sensitive and also relies upon correctly functioning reverse DNS lookup. This is a Kerberos requirement, not specific to Privilege Secure.
    • You can verify this by running nslookup against the LDAP server configured and against the IP presented in the first lookup.
      • e.g.:
        • nslookup name.domain.com
        • nslookup <IP from first nslookup>
    • systemd-resolve --status ens160will show the DNS configured
  • LDAP record referrals are not supported
Appendix
It's recommended to leave Protect Mode disabled when first setting up a domain. Machines should only have Protect Mode enabled after they've been scanned.
NOTE: We require a static DC to ensure S1 can correctly detect and account for changes made to Groups, OUs, Users, etc. A load balanced connection will cause group updates to not be recognized correctly.
