Add a Certificate Authority to the Ubuntu Trusted Authorities Repository
In environments where SSL Inspection/Decryption is used, it may be necessary to include the Certificate Authority’s public cert in the “ca-certificates” repo on Ubuntu. This will enable downloads (for upgrades and so on) to transpire without receiving SSL Handshake errors.
command to output the Certificate Authority
NOTE: This example uses a fake proxy at “192.168.0.3”. Please replace with the real proxy, or, if no explicit proxy is used, remove the proxy argument altogether:
echo -n | openssl s_client -proxy 192.168.0.3:8080 -showcerts -connect google.com:443 | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p’
Save output as MyCA.crt
copy bottom certificate in the output (from "BEGIN_CERTIFICATE" to "END_CERTIFICATE") into MyCA.crt in "/usr/share/ca-certificates"
check the cert
openssl x509 -in MyCA.crt -text -noout
test to google using self signed cert (should fail)
"ERROR: cannot verify google.com's certificate, issued by 'O=mitmproxy,CN=mitmproxy': " Self-signed certificate encountered.
get --delete-after https://google.com -e use_proxy=on -e https_proxy=192.168.0.3:8080
gui to add the MyCA.crt cert
sudo dpkg-reconfigure ca-certificates
test should pass now
wget --delete-after https://google.com -e use_proxy=on -e https_proxy=192.168.0.3:8080
Proxy request sent, awaiting response... 301 Moved Permanently
