Controlling Session Timeouts with GPO
Summary
- Microsoft's Windows operating systems are designed such that a session established with privilege retains that level of privilege as long as the session is active, i.e. the user has not explicitly logged out. There are many methods a user can interface with a Windows OS: Remote Desktop, Powershell, console, direct logon, rpc, scheduled tasks, etc.
- Windows handles the user logon sessions, and the user logon session is not restricted by the method it was initiated. For example, Remote Desktop is a method of interfacing, but Remote Desktop itself does not define what permissions a user has during the initiated session, Windows does. When a user signs on with admin rights, credentials are cached in memory for an indefinite amount of time and associated with the user's account. Cached credentials are removed from memory when the user is logged out or the system reboots. Cached credentials are generally valid until the user password is changed.
- This behavior can create confusion because with respect to remote connections, the session must be explicitly logged out and not simply disconnected in order for the session with the privilege to truly be terminated, regardless of the method used to interface with the Windows endpoint.
Problem Statement
In the last bullet example above, where a remote session with privilege is disconnected and not logged out of, that disconnected session remains available to re-establish connection until that user logs off or the system security policy terminates the session. The default time-out/termination value of this token is often long-lasting: a default of 2 days, sometimes longer if customized. While this token is still valid, adding a user to the Remote Desktop Users group and establishing a session will reconnect this user to the same session previously established with privilege. Clearly, this presents a potential loophole for privileged access; it is critical to make sure cannot be accidentally or intentionally exploited.
Solutions
There are three primary paths for solving this problem:
- Controlling RDP access exclusively via the management of the Local Administrators Group, in line with Privilege Secure's default approach in every way.
- Enforcing a GPO policy that equates a disconnect event with a log-off event, thereby ensuring that the token associated with the admin session is removed every time both a log-off and disconnect to a session takes place. DISCLAIMER: This approach is not a comprehensive solution for every remote login use case, and can potentially be very operationally disruptive. As such, it should be approached strategically and with caution.
- Configure Remote Desktop to log off users after a period of inactivity: https://techexpert.tips/windows/gpo-logoff-remote-desktop-user-after-inactivity-logoff/
Microsoft has designed RDP to have incredibly granular controls regarding specific policies and actions which can be explored for additional layers of control over the RDP interface, specifically:
In this context, it is important to set a policy that forces a disconnected or idle session to also log off.
