Update Privilege Secure OS on Appliances
The best practice for installing Privilege Secure OS updates is to do so during a scheduled maintenance window, and with all services scaled down. This prevents potential issue should an update require a reboot of the server or Docker service.
There are different options to fit your environment or downtime tolerance.
- Cluster: No downtime
- Single-Node: Downtime during reboot
This is a guide to updating the OS on Privilege Secure node with that best practice in mind. Privilege Secure will be offline for 30-60 minutes.
Requirements
- 30-60 minute scheduled maintenance window with expected downtim
- Install the S1 CLI Helper Utility
Use Case: Cluster In-Place (1 node at a Time, No Downtime)
Check DB replication status, “stateStr” should be “PRIMARY” or "SECONDARY"; and replication time difference, a few seconds is acceptable:
mEvl="sudo docker exec -it $(sudo docker ps | grep mongo | cut -d' ' -f1) mongo SecureONESecureONE --quiet --eval"; $mEvl 'rs.status()' | grep "name\|stateStr\|lastHeartbeatRecv\|
\|lastHeartbeatMessage" | column -t; echo; $mEvl 'rs.printSlaveReplicationInfo()'; unset
mEvl
NOTE: If the database replication is not in healthy state, resolve that before continuing.
Primary node only: Check Privilege Secure services and nodes status:
s1 status; s1 nodes
Check for the swarm leader:
s1 nodes | grep Leader
Only if the node being updated has a MANAGER STATUS of leader, run the below command on a different
node to change the swarm Leader. Replace <hostname>
with the hostname of the node being upgraded
and run the command below.
HNupg=`<hostname>` ; sudo docker node demote $HNupg; sleep 10; sudo docker node promote $HNupg
Verify swarm leader is no longer the node being updated:
Process one node completely before moving on to another node:
List nodes with:
- s1 nodes
Drain node to be updated:
- sudo docker node update --availability drain
<hostname>
Verify “Availability” is set to “Drain” with:
- s1 nodes
SSH to the node being updated
Step 1 – Download Update Package Information.
- sudo apt update
Step 2 – Install package updates.
- sudo apt -y upgrade
NOTE: If prompted to replace a configuration file or setting, always use the option to keep the existing configurations, setting, or file.
Step 3 – Reboot if required.
sudo cat /var/run/reboot-required
Result if reboot is required: "*** System restart required ***"
Result if reboot not required: "cat: /var/run/reboot-required: No such file or directory"
If required, reboot node:
- sudo reboot
Step 4 – Once reboot has started, return to the other node. S
Set drained node to active from a different node:
- sudo docker node update --availability active
<hostname>
Monitor for the node to complete rebooting with:
watch s1 nodes
- Verify “Availability” is set to “Active” on updated node.
Once the updated node is reachable, Ctrl+C to get out of the watch command
mEvl="sudo docker exec -it $(sudo docker ps | grep mongo | cut -d' ' -f1) mongo SecureONE --quiet --eval"; $mEvl 'rs.status()' | grep "name\|stateStr\|lastHeartbeatRecv\|lastHeartbeatMessage" | column -t; echo; $mEvl 'rs.printSlaveReplicationInfo()'; unset mEvl
Step 5 – Check Privilege Secure services and nodes status:
- s1 status; s1 node
Step 6 – Move on to next node.
Step 7 – After all nodes completed, check Privilege Secure services and nodes status:
- s1 status; s1 nodes
Use Case: Single-Node (Downtime During Reboot)
Step 1 – Check Privilege Secure services and nodes status.
Step 2 – Download Update Package Information.
- sudo apt update
Step 3 – Install package updates.
sudo apt -y upgrade
Step 4 – Reboot if required.
- sudo reboot
Step 5 – After reboot complete, log in and check Privilege Secure services and nodes status:
