Add a User or Group to a Systems' Administrator Account Inventory
Follow the steps to add an AD User or Group to a Windows or Linux System in Protect Mode.
NOTE: A local administrator account should only be added to protected systems for use cases that require the accounts to be persisted, e.g service accounts.
Step 1 – Locate the system in the Access > Grant Access page.
Step 2 – Click the +Add Account button in the upper right corner of the window.
Step 3 – Use a string to search for the AD user/group and click on the desired AD user/group.
Step 4 – Windows: Select Just-In-Time or Persistent and either the Save or Save and add another button.
Step 5 – Linux: Select All Sudo permission allowed or Specify Sudo permissions.
- If adding a group, all users getting JITA permission for this system from this group will inherit the sudo permissions assigned to the group.
- If specifying specific sudo permission, use sudo file syntax, example provided before editing field.
Step 6 – Click either the Save or Save and add another button.
Adding a local User or Group Account to a Windows or Linux System in Protect Mode
Step 1 – Protect mode JITA is required. If system in Protect Mode: Deny, change to JITA temporarily to add user and/or group. (Privilege Secure administrator required.)
Step 2 – On the system: Add the local user and/or group to the system:
- Windows – Add to the local Administrators group.
- Linux – Add using
sudo visudo
Step 3 – Rescan the system in Privilege Secure.
Step 4 – The local user and or group should now appear in the system's Administrator Account Inventory.
Step 5 – In the systems' Administrator Account Inventory, for the added account, select Action > Set Persistent (Privilege Secure administrator required.)
Step 6 – Rescan the system.
Bulk Actions
Bulk actions for adding AD users and/or groups to multiple system inventories is currently being developed.
QuickStart
QuickStart can be used to provision user and/or groups to one or more systems using the Computer Data Sheet, Provision Account column.
For additional information, see the following topics:
Replicate sudo permissions to one or many systems:
