Quickstart Fields Demystified
The following tables provide details and explanations of the Quickstart report fields.
Admin List Sheet
Sheet FieldQS Field TypeDescriptionPrivilege Secure or LDAP/AD AttributeDB 'ldap_store' Computer Document Feild
isPulled/Downloaded dataIdentifier for the user.Privilege Secure_id
systemPulled/Downloaded dataComputer system attribute returned from LDAP/ADLDAP/ADcn
domainPulled/Downloaded dataAccount's NetBIOS nameLDAP/ADadmins.current.domain
userPulled/Downloaded dataUsername of account (AD sAMAccountName attribute)LDAP/ADadmins.current.user
sidPulled/Downloaded dataSID identifier of the accountLDAP/ADadmins.current.sid
typePulled/Downloaded dataDefining the type of account; 2=Group, 1=UserLDAP/ADadmins.current.sidusage
localPulled/Downloaded dataTrue/False to an local computer account.  True when the computer's cn equals the admin's domain.n/an/a
onHostPulled/Downloaded dataTrue/False flag if the account is in the local administrators group on the computer.Privilege Secureadmins.current.onHost
persistentPulled/Downloaded dataTrue/False flag if the account is marked as persistent. Persistent accounts will not be removed from the local administrators group.Privilege Secureadmins.current.persistent
default_adminPulled/Downloaded dataExists and is True if the account is the built-in admin account on a Windows endpoint (e.g. Administrator). If Privilege Secure has managed this account, the current and previous passwords can be retrieved using the Computer Local Account Password API.Privilege Secureadmins.current.default_admin
inserted_tsPulled/Downloaded dataTimestamp when the record was created in the Privilege Secure database.Privilege Secureadmins.current.inserted_ts
Intentionally Blank--Intentionally left blank.----
FilteredPulled/Downloaded dataTRUE indicates a Windows Server OS found in AD.  FALSE indicates a Window OS without 'server' in the OS name found in AD.Privilege Secure
PersistentChange to push/uploadTrue/False flag to set administrator persistence on computer:  True = persistent; False = non-persistentPrivilege Secureadmins.current.persistent
Delete from InventoryChange to push/uploadTrue flag to delete this administrator from the computer's Administor Accounts inventory.Privilege Secureadmins.current.<admin in array>
Computer Data Sheet
Sheet FieldQS Field TypeDescriptionPrivilege Secure or LDAP/AD AttributeDB Field in 'ldap_store' Collection
idPulled/Downloaded dataIdentifier for the computerPrivilege Secure_id
cnPulled/Downloaded dataComputer cn attribute returned from LDAP/ADLDAP/ADcn
domain_fqdnPulled/Downloaded dataComputer's domain FQDN returned from LDAP/ADLDAP/ADdomain_fqdn
distinguishedNamePulled/Downloaded dataComputer distinguishedName attribute returned from LDAP/ADLDAP/ADdistinguishedName
OUPulled/Downloaded dataOU derived from distinguishedName returned from LDAP/ADPrivilege Securen/a
operatingSystemPulled/Downloaded dataComputer operatingSystem attribute returned from LDAP/ADLDAP/ADoperatingSystem
lastLogonTimestampPulled/Downloaded dataComputer lastLogonTimestamp attribute returned from LDAP/ADLDAP/ADlastLogonTimestamp
last_scannedPulled/Downloaded dataDetails about the last scan attempt by Privilege SecurePrivilege Securelast_scanned
prev_scan_successPulled/Downloaded dataTimestamp when the computer was last successfully scannedPrivilege SecurelastScan.success
prev_scan_msgPulled/Downloaded dataMessage from the last scan attempt by Privilege SecurePrivilege SecurelastScan.msg
Scanned in last 2 weeksPulled/Downloaded dataTrue/False flag that indicates that the computer was scanned in the last 2 weeks, based off last_scanned field date.Privilege Securen/a
protect_modePulled/Downloaded dataIndicates computer's Protect Mode setting:  JITA, DENY, or FALSE (disabled)Privilege Securepolicy .secure
scan_modePulled/Downloaded dataTrue/False flag that indicates if the computer is included in active permission scans.Privilege Securepolicy.scan
directory_bridging_strategyPulled/Downloaded dataIndicates directory bridging provider set for Linux computer.
edr_integrationPulled/Downloaded dataIndicates if Privilege Secure EDR (Endpoint Detection and Response) integration is enabled for computer.Privilege Secureconfig.edr_integration.enabled
registeredPulled/Downloaded dataMac registered system
<QuickStart provisionUser>Pulled/Downloaded dataTrue/False flag that indicates if the provisionUser specificed in the QuickStart script is on a computer.Privilege Securen/a
OAM (Offline Access Management) EnabledPulled/Downloaded dataTrue/False flag that indicates if OAM is managed on computer.config.policies.offline_access_management.enabled
OAM StrategyPulled/Downloaded dataIndicates current OAM strategy set for computerPrivilege Secureconfig.policies.offline_access_management.strategy
OAM Name TemplatePulled/Downloaded dataCurrenlty set name template for OAM alternate administrator account. Wildcards expressed by question marks (?).  Default value is S1_ALT_ADMIN.Privilege Secureconfig.policies.offline_access_management.break_glass_account_name_template
OAM JITA User Can Access PWPulled/Downloaded dataTrue/False flag that indicates Privilege Secure application “User” role members with JITA or persistent access to systems to access OAM passwords.Privilege Secureconfig.policies.offline_access_management.jita_or_persistent_users_can_access_passwords
OAM Use Alt AdminPulled/Downloaded dataTrue/False flag that indicates if Privilege Secure is to create and use an Alternate Admin account, named according to the OAM Name Template.Privilege Secureconfig.policies.offline_access_management.use_alternate_admin
OAM Manage Built-in PWPulled/Downloaded dataTrue/False flag indicating if Privilege Secure is managing the computer's built-in local administrator (RID 500) account password.Privilege Secureconfig.policies.offline_access_management.manage_built_in_admin_password
OAM Disable Built-in AdminPulled/Downloaded dataTrue/False flag that indicates if Privilege Secure will disable computer's built-in local administrator account (RID 500).Privilege Secureconfig.policies.offline_access_management.disable_built_in_admin
Enable ProtectChange to push/uploadSet computer's Protect Mode:  JITA, DENY, or FLASE (disabled)Privilege Securepolicy .secure
Enable ScanChange to push/uploadTrue/False flag setting indicates if the computer is included in active permission scans.Privilege Securepolicy.scan
Enable EDR IntegrationChange to push/uploadTrue/False flag  setting Privilege Secure EDR (Endpoint Detection and Response) integration:  True = enabled; False = disabledPrivilege Secureconfig.edr_integration.enabled
Provision AccountChange to push/uploadDOMAIN\sAMAccountName.  Comma delimited.  To persist add ;true after sAMAccountName (still comma delimited).Privilege Secure
Set OAM EnabledChange to push/uploadTrue/False flag setting Privilege Secure OAM managment of computer:  True = enabled; False = disabled If set to false with no other parameters, then other OAM existing values will be left as-is, and only the enabled field will be set accordingly.Privilege Secureconfig.policies.offline_access_management.enabled
Set OAM StrategyChange to push/uploadSet OAM strategy.  May be entered with any of following case-insensitive values:  OS-BEST-PRACTICE MANAGED-BUILT-IN CUSTOM If left blank it will default to the current value, or to OS-BEST-PRACTICE if no previous policy was set.Privilege Secureconfig.policies.offline_access_management.strategy
Set OAM Name TemplateChange to push/uploadName template for OAM alternate administrator account. Accepts a string with wildcards expressed by question marks (?) ex: MYADMIN???. If left blank it will default to the current value, or to S1_ALT_ADMIN.Privilege Secureconfig.policies.offline_access_management.break_glass_account_name_template
Set OAM JITA User Can Access PWChange to push/uploadTrue/False flag setting Privilege Secure “Users” with JITA/persistent access to systems access OAM passwords:  True = access; False = no accessPrivilege Secureconfig.policies.offline_access_management.jita_or_persistent_users_can_access_passwords
Set OAM Use Alt AdminChange to push/uploadTrue/False flag setting creation and use of an Alternate Administrator account, named according to the OAM Name Template:  True = create/use; False = Do not create/usePrivilege Secureconfig.policies.offline_access_management.use_alternate_admin
Set OAM Manage Built-in PWChange to push/uploadTrue/False flag setting management of built-in local administrator (RID 500) account password:  True = manage; False = do not managePrivilege Secureconfig.policies.offline_access_management.manage_built_in_admin_password
Set OAM Disable Built-in AdminChange to push/uploadTrue/False flag setting if Privilege Secure is to disable computer's built-in local administrator account (RID 500):  True = disable; False = do not disablePrivilege Secureconfig.policies.offline_access_management.disable_built_in_admin
Set Directory Bridging StrategyChange to push/uploadSet directory bridging provider for Linux computer:  privilegesecure, centrify, powerbrokerPrivilege Secureconfig.directory_bridging.strategy
Set Directory Bridging DomainChange to push/uploadSet domain for bridging provider for Linux computer if not set to Privilege Secure.Privilege Securedomain_fqdn
Set Sudoers RepresentationChange to push/uploadInsert sudoers ID from a computer to replicated that sudoers file to other computer(s)Privilege Securestaged_sudoers_history.sudoers_hash
