Remove a System from Privilege Secure
This article covers the proper sequence to remove Privilege Secure OAM and protection from a system.
Windows Systems
Step 1 – Log into Netwrix Privilege Secure for Discovery UI.
Step 2 – Find system using the 'Grant Access' page.
Step 3 – Persist any accounts you want to remain in local Administrators group.
Step 4 – If OAM enabled:
  • Set OAM to Unmanaged (if applicable).
  • Rescan.
  • Copy the last know password for the built-in Administrator account.
Step 5 – Set Protect Mode and Scan Mode to disabled (no need to rescan).
Step 6 – RDP or locally log into system .
Step 7 – Remove the Privilege Secure service account from local Administrators group.
Privilege Secure now has no access to change local Administrators group.
NOTE: If you just remove the Privilege Secure service account from the system, one or more of the following can result:
  • OAM alternate administrator account remains in the system
  • The built-in Administrator will remain disabled
  • No accounts will be added back into the local Administrators group
Linux Systems
Step 1 – Log into the Netwrix Privilege Secure for Discovery UI.
Step 3 – Persist any accounts you want to retain sudo privileges.
Step 4 – Rescan.
Step 6 – SSH or locally log into system.
Step 7 – Remove sudo privileges for the Privilege Secure service account.
Step 8 – Remove Privilege Secure
Privilege Secure now has no access to this system.
