403 - Zero USNs by Domain
Privilege Secure must point to a single Domain Controller (DC). This is because Privilege Secure uses the USN values from Active Directory to determine when a group has been changed. These do no propagate between DCs.
When a DC is unavailable a new one can easily be connected to using the Privilege Secure UI. However, when this occurs, if the USN number is lower, Privilege Secure will not be aware of changes to groups. This will impact access from changed groups.
It is recommended to force a re-sync of Privilege Secure's LDAP information when a DC is changed. This is suggested during the next available maintenance window at the end of the day.
The script detailed in this article can be used to zero the USN for an impacted domain.
Script Flow
Script generate a menu list of domains by NETBIOS
User selects the number for the domain will zero the highest_usn and previous_usn db values
For selected domain, script will:
Display pre-zero USN counts
Prompt for confirmation before zeroing
Display post-zero USN counts
Run script multiple times to zero USNs on multiple domains
Notes
- MongoDB shell command to check USNs by netbios. Script runs this before and after zero for the
domain zerored. Including here for manual runs:
db.discovery_config.find({type:"ldap_config"},{_id:0, domain_netbios:1,"sync.previous_usn":1,"sync.highest_usn":1})
Command to Create Script File, Open in VIM, and Make Executable
sudo vim /secureone/setup/zero_domain_usns.sh && sudo chmod +x /secureone/setup/zero_domain_usns.sh
Script Contents
#!/bin/bash## Script to select a domain to zero highest_usn and previous_usn db valuesS1ENV=$(sudo docker node ls --format "{{.Hostname}}" | wc -l)MCtnr=$(sudo docker ps | grep mongo | cut -d' ' -f1)if [ $S1ENV == 5 ]; then DBEnv="mongodb://mongo1,mongo2,mongo3,mongo4,mongo5/SecureONE?replicaSet=secureone"elif [ $S1ENV == 3 ]; then DBEnv="mongodb://mongo1,mongo2,mongo3/SecureONE?replicaSet=secureone"elif [ $S1ENV == 1 ]; then DBEnv="SecureONE"else echo "Script does not support S1ENV nodes for domain_netbios lookup."fiDmenu=$(sudo docker exec -t $MCtnr mongo --quiet $DBEnv \ --eval 'DBQuery.shellBatchSize = 999999999;db.secureone_config.distinct("domain_netbios",{"type":"ldap_config"})' | \ grep -v $(date +'%Y-%m-%d') | tr -d [], | xargs)echo; echo "Detected domain_netbios entries:"PS3="Enter number for domain to zero USNs: "select Dselected in $Dmenudo echo; echo "Current USN values for $Dselected" ## display current highest_usn and previous_usn values for the domain sudo docker exec -t $MCtnr mongo --quiet $DBEnv --eval \ 'DBQuery.shellBatchSize = 999999999; db.secureone_config.find({type:"ldap_config","domain_netbios":"'"${Dselected}"'"}, {_id:0, domain_netbios:1,"sync.previous_usn":1,"sync.highest_usn":1})' | \ grep -v $(date +'%Y-%m-%d') | tr -d {}\" | sed 's/sync ://g' echo #echo "Zero USNs for $Dselected, are you sure?" read -n 1 -p "Zero USNs for $Dselected, are you sure? [ Y ] to continue, any other key to abort." reply; if [ "$reply" != "" ]; then echo; fi if [ "$reply" = "${reply#[Yy]}" ]; then echo; exit fi ## zeroing the highest_usn and previous_usn values for the domain sudo docker exec -t $MCtnr mongo --quiet $DBEnv --eval \ 'db.secureone_config.updateOne({type:"ldap_config","domain_netbios":"'"${Dselected}"'"},{$set:{"sync.highest_usn":NumberInt(0)}})' | \ grep -v $(date +'%Y-%m-%d') sudo docker exec -t $MCtnr mongo --quiet $DBEnv --eval \ 'db.secureone_config.updateOne({type:"ldap_config","domain_netbios":"'"${Dselected}"'"},{$set:{"sync.previous_usn":NumberInt(0)}})' | \ grep -v $(date +'%Y-%m-%d') ## display current highest_usn and previous_usn values for the domain echo sudo docker exec -t $MCtnr mongo --quiet $DBEnv --eval \ 'DBQuery.shellBatchSize = 999999999; db.secureone_config.find({type:"ldap_config","domain_netbios":"'"${Dselected}"'"}, {_id:0, domain_netbios:1,"sync.previous_usn":1,"sync.highest_usn":1})' | \ grep -v $(date +'%Y-%m-%d') | tr -d {}\" | sed 's/sync ://g' echo; echo "Completed zeroing USNs for $Dselected" exitdoneunset S1ENVunset MCtnrunset Dmenuunset reply
Command to Run Script
sudo /secureone/setup/zero_domain_usns.sh
The Customer Success Team can assist with setting this up prior to utilization.
Here is an example of a successful run against the CSTEST domain in one of the Customer Support labs:
secureone@ip-10-100-11-40:~$ sudo /secureone/setup/zero_domain_usns.shDetected domain_netbios entries:1) CSTESTEnter number for domain to zero USNs: 1Current USN values for CSTESTdomain_netbios : CSTEST, highest_usn : 2405725, previous_usn : 2405725Zero USNs for CSTEST, are you sure?[ Y ] to continue, any other key to abort.y{ "acknowledged" : true, "matchedCount" : 1, "modifiedCount" : 1 }domain_netbios : CSTEST, highest_usn : 0, previous_usn : 0Completed zeroing USNs for CSTESTsecureone@ip-10-100-11-40:~$
