Registering and Using the sbpam-url SSH Protocol Handler
Overview​
The sbpam-url utility, located in the Extras folder of the download package, registers an SSH URL handler. This utility helps you automatically connect to an NPS-proxied SSH session.
For additional information, refer to the following article: Invoking Desktop SSH Client Automatically
At the time this article was written, the referenced KB article instructed users to download the utility from a static link, which may provide an outdated version. Use the utility bundled in the Extras folder to ensure you have the latest version.
Instructions​
Where to Install or Run the Utility​
The URL handler must be registered on the machine where NPS users run their browser. Ensure you run the utility on the appropriate client system.
Example Commands for External SSH Clients​
Use the following PowerShell commands and arguments for various external SSH clients:
# Register Putty
& .\sbpam-url handle -p ssh -- "C:\Program Files\PuTTY\putty.exe" -ssh -P '{{port}}' '{{user}}@{{hostname}}'
# Register Windows 10 (OpenSSH)
& .\sbpam-url handle -p ssh -- C:\Windows\System32\OpenSSH\ssh.exe '\{\{URL\}\}'
# Register RoyalTS
& .\sbpam-url handle -p ssh -- "C:\Program Files (x86)\Royal TS V5\RoyalTS.exe" '/username:{{user}}' /password:a /protocol:terminal /using:adhoc '/uri:ssh://{{host}}'
# Register MobaXTerm
& .\sbpam-url handle -p ssh -- "C:\Apps\MobaXterm_Professional_9.4\MobaXterm_Professional_9.4.exe" -newtab 'ssh -o PasswordAuthentication=no -l {{user_esc}} -p {{port}} {{hostname}}'
NOTE: Each time you run the handle command, it replaces the previous handler with the new one.
Remove the SSH Handler​
& .\sbpam-url handle -U -p ssh
General Command-Line Form​
Use the following syntax to register a handler:
sbpam-url handle -p <protocol> -- <Command to run using replacement strings>
Available Commands​
CommandDescription
completionGenerate the autocompletion script for the specified shell.
handleRegister a URL handler.
helpDisplay help about any command.
Command Flags​
FlagDescription
-h, --helpDisplay help for sbpam-url.
-d, --debugDisplay debug messages.
-Q, --quietDo not display messages.
-u, --url stringURL to handle.
-v, --versionDisplay version information.
handle -p <protocol>Handle the specified protocol.
handle -uUnregister all protocols.
handle -u -p <protocol>Unregister a specific protocol.
Available Replacement Strings​
Replacement StringDescription
{{scheme}}Protocol, for example, SSH.
{{user}}User portion of the URL (direct connect string).
{{user_esc}}Escaped user portion of the URL.
{{host}}The host and port in the format host:port.
{{hostname}}Just the hostname.
{{port}}Just the port.
{{path}}The URL path.
{{query}}The URL query.
{{fragment}}The URL fragment.
{{password}}The password portion of the URL.
Alternatives to sbpam-url​
You can use WinSCP to install an SSH handler as an alternative to sbpam-url. Note that WinSCP requires Putty to be installed first.
Registry Keys Modified by sbpam-url​
The sbpam-url utility updates the following registry keys to register the protocol handler:
[HKEY_CLASSES_ROOT\ssh]
@="URL: ssh Protocol"
"URL Protocol"=""
"EditFlags"=dword:00000002
"BrowserFlags"=dword:00000008
[HKEY_CLASSES_ROOT\ssh\DefaultIcon]
[HKEY_CLASSES_ROOT\ssh\shell]
[HKEY_CLASSES_ROOT\ssh\shell\open]
[HKEY_CLASSES_ROOT\ssh\shell\open\command]
[HKEY_CURRENT_USER\Software\Classes\SbPAM.URL]
@="SbPAM URL Handler"
"URL Protocol"=""
"DefaultIcon"=""
[HKEY_CURRENT_USER\Software\Classes\SbPAM.URL\shell]
[HKEY_CURRENT_USER\Software\Classes\SbPAM.URL\shell\open]
[HKEY_CURRENT_USER\Software\Classes\SbPAM.URL\shell\open\command]
@=""" --url "%1""
[HKEY_CURRENT_USER\Software\Classes\Applications\sbpam-url.exe]
"FriendlyAppName"="SbPAM URL Handler"
[HKEY_CURRENT_USER\Software\RegisteredApplications]
"SbPAM"="Software\Stealthbits\SbPAM\SbPAM.URL\Capabilities"
[HKEY_CURRENT_USER\Software\Stealthbits\SbPAM\SbPAM.URL\Capabilities]
"ApplicationDescription"="SbPAM handler application for URLs"
"ApplicationName"="SbPAM URL Handler"
[HKEY_CURRENT_USER\Software\Stealthbits\SbPAM\SbPAM.URL\Capabilities\UrlAssociations]
[HKEY_CURRENT_USER\Software\Stealthbits\SbPAM\SbPAM.URL\URLHandlers]
"ssh"=""
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\Associations\UrlAssociations\ssh\UserChoice]
"Progid"="SbPAM.URL"
