Resolving "Invalid Connection String" for DirectConnect in mRemoteNG
Summary​
In a specific scenario, valid Netwrix Privilege Secure DirectConnect strings used in mRemoteNG will result in an invalid connection string error, stating the connection string is empty.
Screenshot of Netwrix Privilege Secure DirectConnect error, stating the connection string is invalid (empty).
Instructions​
This error is caused by having credentials saved for the Netwrix Privilege Secure server (for example, the Netwrix Privilege Secure Proxy Server) in the Windows built-in RDP client, Remote Desktop Connection, on the same host that is running mRemoteNG.
Screenshot of a credential saved in Remote Desktop Connection, the built-in Windows RDP client, for the Netwrix Privilege Secure Proxy Server.
To resolve the issue, you have two options:
  1. Delete the credential saved in Remote Desktop Connection. After you delete that credential, the valid DirectConnect string will work as expected in mRemoteNG.
  2. Fill in a password for each DirectConnect connection saved in mRemoteNG. This resolves the issue without deleting any credentials from Remote Desktop Connection.
