Resolving "No Common Algorithm for Key Exchange" SSH Error for Cisco Resources
Overview​
IMPORTANT: This article applies only to Cisco connections.
It may occur that Netwrix Privilege Secure is not configured to use the same key exchange algorithm as a target resource when brokering an SSH connection. This will cause the following error to appear in the PAM-SSHClient log:
Error="ssh: handshake failed: ssh: no common algorithm for key exchange; client offered: [ARRAY_OF_ALGORITHMS], server offered: [ARRAY_OF_ALGORITHMS]"
NOTE: Here, the two arrays of algorithms would not contain any shared algorithms.
Instructions​
Refer to the following steps to configure the use of the same key exchange algorithm as a target resource when brokering an SSH connection:
  1. Choose an acceptable algorithm from the list of server offered algorithms given in the error message you have received. For example, suppose your server offered diffie-hellman-group14-sha1.
  2. On your Netwrix Privilege Secure server, navigate to the ActionServiceWorker directory.
    NOTE: On a default installation, it should be C:\Program Files\Stealthbits\PAM\ActionServiceWorker
  3. Open the sbpam_sshclient.json file in a text editor.
  4. Navigate to the KeyExchanges section, which should resemble the following:
"KeyExchanges": [
"diffie-hellman-group-exchange-sha256",
"diffie-hellman-group-exchange-sha1",
"diffie-hellman-group1-sha1"
  1. Modify the array to include your desired algorithm, keeping the array properly comma-separated. In our example:
"KeyExchanges": [
"diffie-hellman-group1-sha1",
"diffie-hellman-group14-sha1"
  1. You should now be able to negotiate an SSH connection with the target resource using its preferred algorithm.
