Disable Keystroke Logging
Question​
How to disable keystroke logging (keylogging) in Netwrix Privilege Secure?
Answer​
IMPORTANT: The following steps will disable all screen recordings of SSH activity.
Locate the sbpam_iolog.json file in the C:\ProgramData\Stealthbits\PAM\ProxyService directory. Edit it to include the following lines:
"idletimeout" : 300000000000,
"path" : "C:\ProgramData\Stealthbits\PAM\ProxyService\iolog",
"replicas" : 1,
"disableMetadata" : true
If no such file exists in the directory, create it, name it sbpam_iolog.json, and add the lines in the code block to the new file. Save the changes — this will disable all metadata recording, keylogging, and capture of all SSH session recordings.
IMPORTANT: This will not affect the previous records.
Delete recordings from a specific time window​
  1. Locate the iolog directory — the default path is C:\ProgramData\Stealthbits\PAM\ProxyService\iolog.
  2. Sort the contents by date and delete the folders matching the desired time window.
  3. Locate the sbpam_metadata database in the C:\ProgramData\Stealthbits\PAM\ProxyService\iolog\.meta directory and delete it.
  4. Run the following PostgreSQL query to delete references for recordings:
delete from proxy_session where start_datetime_utc <= '2023-10-31 13:54:22.315271';
