How MySystems Works
Question​
How does MySystems work, and why do users see only some systems?
Answer​
Netwrix Privilege Secure for Discovery builds a cache named MySystems for each user. Users with the User role can see only the systems on which they have just-in-time access (JITA) or persistent access.
After you sign in, you have access to the following menu items:
  • Overview
  • Grant Access
  • Insight
  • Systems
  • Monitor
NOTE: Insight might not be available, depending on how the environment is configured. It can be an administrator-only feature.
JITA and Persistent Access​
If you have the User role, searches for computers in Grant Access, Insight, or Systems Management, and queries through the API, return only the systems on which you have JITA access or persistent access.
You have JITA access to a system when your Active Directory (AD) user account is in the Administrators Inventory for that system. Your account can be in the inventory in any of the following ways:
  • Directly in the Administrators Inventory.
  • As a member of an AD group that is in the Administrators Inventory.
  • As a member of an AD group that is nested in an AD group in the Administrators Inventory.
You have persistent access to a system when any of the following is true:
  • Your user account is directly in the Administrators Inventory and set to persistent.
  • You are a member of an AD group in the Administrators Inventory that is set to persistent.
  • You are a member of an AD group that is nested in a persistent AD group in the Administrators Inventory.
Cache Creation​
The product generates the MySystems cache after you sign in, when you use the Grant Access search or open Management > Systems. While the cache is being generated, a toast notification indicates that it is not yet complete.
Please wait message stating that the product is computing the current user's access
The API endpoint that creates the MySystems cache is:
/api/v1/mysystems/createcache
