UnprocessableEntityError: Missing Result for Task checkAdminPrivilege. Code: 9999
Formerly SecureONE
Symptom
Example of error when running registration via QuickStart:
C:\secureone>reports_2.5.py --insecure --linux-reg-file LinuxReg1.xlsx
[+] API key loaded from secure storage
[*] Registering Linux system: linux_1.cstest.com
[!] Error submitting request:
Url: https://secureone.cstest.com/api/v1/computers/register
Response Code: 422
Response Body: {"name":"UnprocessableEntityError","message":"'Missing result for task checkAdminPrivilege'","code":9999}
And when attempting to Rescan in UI, a red pop-up displays for a few seconds with an error like the following:
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY! Someone
could be eavesdropping on you right now (man-in-the-middle
attack)! It is also possible that a host key has just been
changed. The fingerprint for the ECDSA key sent by the remote
host is 14:09:16:4b:aa:da:3c:38:04:97:f0:09:88:03:ba:d6.
Please contact your system administrator. Add correct host
key in /root/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /root/.ssh/known_hosts:1 remove with:
ssh-keygen -f "/root/.ssh/known_hosts" -R 10.100.11.115
Password authentication is disabled to avoid man-in-the-middle
attacks. Keyboard-interactive authentication is disabled to
avoid man-in-the-middle attacks. Permission denied (publickey,
gssapi-keyex,gssapi-with-mic,password).
Cause
This registration error can happen when a system was rebuilt with the same IP and hostname.
Resolution
Restart the worker and scanner services to clear the know_hosts on those services:
  1. Remove the system from the Netwrix Privilege Secure for Discovery database:
    1. SSH into a node and log into the database:
      • For cluster deployment, use: s1 db
      • For a single node deployment: s1 --single-node db
    2. Locate the systems, ip-10-100-11-115 is used as an example hostname:
      db.ldap_store.find({ "cn" : "ip-10-100-11-115"}).count()
    3. Remove all ldap_store record of that system:
      db.ldap_store.deleteMany({ "cn" : "ip-10-100-11-115"})
  2. Restart the worker and scanner services from the UI or with CLI:
    s1 restart scanner worker
  3. Register the system.
