Generate License Counts with CLI Command
Netwrix Privilege Secure Discovery (formerly SecureONE)
The purpose of this document is to outline the steps required to get an accurate license count for Netwrix Privilege Secure Discovery that is on a version older than 2.16.1.
NOTE: Whether the licensing information is gathered from the script or the UI, the numbers should match as the UI is simply a reflection of the script.
Licensing Overview
Netwrix Privilege Secure Discovery is licensed based on systems successfully scanned in the last 90 days. The database queries below can be run from the CLI to get the licensing counts. Add all applicable counts together to get the total licensing count.
CLI Commands
Below is a CLI command to output a count of successfully scanned systems in last 90 days. Only run the command matching the deployment type. Each block of lines is all one command — copy all the lines and paste them in a node terminal (SSH) session.
Cluster deployment command:
CtR=$(sudo docker ps | grep mongo | cut -d' ' -f1); \
DBExQ="sudo docker exec -it $CtR mongo mongodb://mongo1,mongo2,mongo3/SecureONE?replicaSet=secureone --eval"; \
clear;echo "Windows Server Count:"; \
$DBExQ 'db.ldap_store.count({obj_type:"computer", "last_scanned":{$gte:new Date(ISODate().getTime()- 1000*86400*90)}, "operatingSystem":/SERVER/i, "os_type":"windows"})' | \
grep -vi "NETWORK\|Implicit\|MongoDB"; \
echo;echo "Windows Workstation Count:"; \
$DBExQ 'db.ldap_store.count({obj_type:"computer", "last_scanned":{$gte:new Date(ISODate().getTime()- 1000*86400*90)}, "operatingSystem":{$not:/SERVER/i}, "os_type":"windows"})' | \
echo;echo "Linux Server Count:"; \
$DBExQ 'db.ldap_store.count({obj_type:"computer", "last_scanned":{$gte:new Date(ISODate().getTime()- 1000*86400*90)}, "os_type":"linux"})' | \
grep -vi "NETWORK\|Implicit\|MongoDB"; echo
Single-node deployment command:
DBExQ="sudo docker exec -it $CtR mongo SecureONE --eval"; \
Example Output
Below is an example of the output for the above command:
556
3956
Linux Server Count:
156
