Action Service Requirements
The Action Service can be installed on additional servers.
Remember, the Action Service is installed on the Threat Manager Console server.
The Windows server can be physical or virtual. The following Windows server operating systems are supported:
  • Windows Server 2022
  • Windows Server 2019
  • Windows Server 2016
Additionally the server must meet these requirements:
  • US English language installation
RAM, CPU, and Disk Space
Minimum hardware requirements:
  • 4 GB RAM
  • 1 CPU Core
  • 500 MB Total Disk Space
Additional Server Requirements
The following are additional requirements for the application server:
  • .NET 8.0.11
  • .NET Desktop Runtime 8.0.11
  • ASP.NET Core 8.0.11
  • PowerShell 5.1+ installed
Client Requirements
Threat Manager is a web service which can be accessed locally or remotely if the server’s firewall permits it. The supported browsers are:
  • Google Chrome
  • Apple Safari
  • Microsoft Edge
  • Mozilla Firefox
Database Server Requirements
NOTE: Use this information when the database server is separate from the application server.
The following are additional requirements for the database server:
  • .NET 8.0.11
  • VC++ redist v14.28.29914
Additional Considerations
The following considerations must be accommodated for:
  • When running antivirus scans against the PostgreSQL v14 database, the PostgreSQL data folder must be excluded from the scans in order to prevent database complications.
  • For performance reasons, disable Windows File Indexing on the drive containing the Threat Manager database.
  • Disk Defragmentation jobs should never be performed on the drive containing Threat Manager PostgreSQL database. This can cause operational issues with the PostgreSQL database.
Requirements
This topic describes the recommended configuration of the servers needed to install the application in a production environment. Depending on the size of the organization, it is recommended to review your environment and requirements with a Netwrix engineer prior to deployment to ensure all exceptions are covered.
Architecture Overview
The following servers are required for installation of the application:
Core Component
  • Threat Manager Database Server – This is where the Threat Manager PostgreSQL database is installed.
  • Threat Manager Application Server – This is where the v3.0 application is installed.
  • Threat Manager Client – Threat Manager is a web service that can be accessed locally or remotely through a supported browser.
  • Threat Manager Action Service Server – Actions automate security responses and connect various security applications and processes together. The Action Service is installed with Threat Manager on the application server. However, it can be installed on additional servers.
See the following topics for server requirements:
Target Environment Considerations
The target environment encompasses all servers, devices, or infrastructure being monitored by Netwrix Threat Prevention or Netwrix Activity Monitor in addition to data collected by Netwrix Access Analyzer (formerly Enterprise Auditor).
  • Active Directory Activity Data– Active Directory activity data is collected through integration with Threat Prevention or the Activity Monitor.
  • File System Activity Data – File System activity data is collected through integration with Threat Prevention or the Activity Monitor.
  • File System Sensitive Data – File System sensitive data is collected through integration with Access Analyzer.
See the following documents for server requirements:
Application Server Requirements
CAUTION: Netwrix Threat Manager cannot be installed on the same server as Netwrix Threat Manager Reporting Module.
These are dependent upon the total number of daily events sent to Threat Manager. It is suggested to use the total events for a peak day of the week, by activity.
EnvironmentEnterpriseExtra LargeLargeMediumSmallExtra Small
Daily Events130 M90 M45 M21 M4.5 M875 K
RAM64 GB64 GB32 GB32 GB32 GB16 GB
Cores24128844
Daily Disk Usage300 GB170 GB120 GB40 GB10 GB5 GB
Total Disk Space4 TB3 TB2 TB1 TB1 TB1 TB
IOPS8,0005,0003,0002,0001,000500
NOTE: All values are based upon a seven day event retention period in Threat Manager.
Daily events to be monitored by Threat Manager can typically be discovered by using Netwrix Threat Prevention or Netwrix Activity Monitor. When planning a deployment where there is currently no Netwrix agent deployed, it can be more difficult to plan for scale. However, the following are estimations based on organization size can be used:
  • For fewer than 1,000 active users
    • Generally assume 21 million daily events (Medium environment)
  • For 1,000-10,000 active users
    • Generally assume 45 million daily events (Large environment)
  • For more than 10,000 active users
    • Generally assume at minimum 100 million daily events (Extra Large-Enterprise environment)
  • 8 GB RAM
  • 4 CPU Cores
  • 150 GB Disk Space
  • .NET 8.0.11
  • Python v3.10.8x64
Additional Considerations when Database is on the Application Server
Permissions for Installation and Application Use
The following permissions are required to install and use the application:
  • Membership in the local Administrators group
Virtual Environment Recommendations
While physical machines are always preferred, we fully support the use of virtual machines. This section contains special considerations when leveraging virtualization.
  • VMWare® ESX® – If using ESX, the following specifications are recommended:
    • ESX 4.0 / ESXi™ 4.1 or higher
    • Virtual Hardware 7 or higher
    • All Virtual Machines installed on the same datacenter / rack
  • Virtual Storage Consideration
    • In the server requirements, when separate disks are required for the servers, that should translate to separate data stores on the VM host machine.
