Fixing missing python file issue
Issue
During upgrades, Python may fail to lay down files correctly.
Example error:
[ERR] LaunchPythonJob error: System.ComponentModel.Win32Exception (2): The system cannot find the file specified.
If you see this error in your job logs, follow the steps in the following section.
Instructions
First, try to cleanly uninstall Python via Add/Remove Programs and follow these steps:
- Remove registry key
\HKEY_LOCAL_MACHINE\SOFTWARE\Python\PythonCore\3.10 - Uninstall Netwrix Threat Manager
- Re-install Netwrix Threat Manager
If you are unable to cleanly uninstall Python using the above steps, follow these steps then try the above again:
- Go to
C:\Users\%USERNAME%\AppData\Local\Programs - Delete Python Folder
- Go to Control Panel > Uninstall a Program
- Right-click Python and select Change/Modify
- Click Repair Python. The repair may fail — this is expected.
- Return to step 6.
- After step 6, uninstall Python.
- Retry steps 1–3.
Affected Versions
Affected Versions : 2.7.1544+
